Wanted a little more power.....
  • 11 Replies
  • 2088 Views
95XL7
« on: January 26, 2006, 04:06:19 PM »
 ;) Hope this helps out my little Tracker,can always use a little more
get up and go.........
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4607744148&sspagename=STRK%3AMEWA%3AIT
Think i should use a 45,65,or 75 shot?
Offline takai
  • 907
Re: Wanted a little more power.....
« Reply #1 on: January 26, 2006, 04:12:34 PM »
Depends on how long you want your engine to last.  ;)
'Cause, I am to misbehave.
95XL7
« Reply #2 on: January 26, 2006, 04:22:49 PM »
I will start out low,it won't get used very often,just when some dick head try's
to cut me off at a stoplight.
We have alot of intersections around here that
go from 2 lanes down to one lane and some assh.le
always pulls in the lane that
ends and trys to blow past everyone else. ::)
Offline takai
  • 907
« Reply #3 on: January 26, 2006, 04:40:00 PM »
I had considered it for my Sammi a while back. Just not a huge fan of what it can "potentially" do to your engine. More power can be addicting and I know me so, Nitrous is out.  ;D
Offline Dihnekis
  • 398
« Reply #4 on: January 26, 2006, 05:23:06 PM »
How much does it cost to get refilled?
1988 Suzuki Samurai
Offline SloMo228
  • 11
« Reply #5 on: January 26, 2006, 09:03:25 PM »
Around here I believe it costs about $2/lb for N20 refills.
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #6 on: January 26, 2006, 11:44:15 PM »
I think a stock motor can only take like 25 hp shot and no longer that 3 seconds
think that is right
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Yoak
  • 577
« Reply #7 on: January 27, 2006, 10:02:27 PM »
It is a cheap way to get quick power,
I thought about going that route....
but all that for just a 2-3 seconds of extra power...
Dosen't seem worth it to me....
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #8 on: January 28, 2006, 05:21:04 PM »
isn't the 2.7 enough? ;D
95XL7
« Reply #9 on: January 29, 2006, 09:28:26 AM »
 ;D just like SEX,you can never get enough.......
Offline Yoak
  • 577
« Reply #10 on: January 29, 2006, 02:52:08 PM »
 ;D Agreed!
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
« Reply #11 on: January 29, 2006, 08:15:56 PM »
If you can keep enough fuel in with the Nitrous then you'll be fine.  Gotta be on the rich side for nitrous.  Also, that is a "Dry" system.  Dry system doesn't add fuel with the nitrous.  It relies on the computer to add fuel.  So if your fuel pump aint up to snuff or te stock injectors arent big enough then you risk going lean.  If I were to do nitrous, I would get a "wet" system that adds more fuel with the nitrous to help prevent a lean condition thus destroying your motor.
I have a 68 Chevy C10 2wd with a supercharged 355.  525HP is good enough for right now, but HP is way TOO addicting.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
