Starting problem
  • 1907 Views
Offline Dark Negotiator
  • 24
  • The Infamous
    • MySpace
Starting problem
« on: January 25, 2006, 09:51:14 AM »
my tracker is 95 16v, new battery, battery wires, starter, and alt was checked.
sometimes when I go to start my tracker it just clicks once as I turn the key but thats it. If I keep turning the key over and over it eventualy starts. when it finally does start the starter doesnt strugle to get the engine running it fires right up. Other times I have no problems and it starts on the first try. Its been doing this for over a year now, it always starts it just takes a bit longer sometimes.
Offline takai
  • 907
Re: Starting problem
« Reply #1 on: January 25, 2006, 11:27:08 AM »
You could possibly have a loose wire somewhere in the system. That is what I would look for. It might be in the ignition switch itself but, I highly doubt it.
'Cause, I am to misbehave.
  • 24
  • The Infamous
    • MySpace
« Reply #2 on: January 25, 2006, 12:11:39 PM »
I have no idea where to look.
  • 24
  • The Infamous
    • MySpace
« Reply #3 on: January 26, 2006, 09:11:13 AM »
Any other ideas?
Offline Yoak
  • 577
« Reply #4 on: January 27, 2006, 05:38:05 PM »
Do you happen to have an MSD on there?....
Mind was doing the same thing (w/ msd)...when it was cold out or the humidity was up....
My msd eventually died on me (just a few days back)...removed it and it starts up just fine...
Check the connection w/ blaster coil....
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« Reply #5 on: January 27, 2006, 07:49:15 PM »
welcome in the "cliky starter club"
sorry for my english is verry bad....
the probleme its the wire conected on the seleniod to the key switch....i have some page in english for this probleme !!!
http://www.izook.com/reviews/clicky_fix/clickyfix.htm
http://www.zookpower.ca/forums/showthread.php?t=802
http://bbs.zuwharrie.com/content/topic,15958.0.html
http://shop.store.yahoo.com/mobile-emotions/relays.html
you find the relay at all auto part shop !!!
more question ask me no probleme :)
take care !!!
Sidekick 90 2 Door
3" Body Lift
2" Suspention Calmini
31 Mud BFG !!!
