No i'am not talking about your ol'ladies....
As you may know i recently purchased a rear 3rd member from a 91-93 kick with 5:38
gears which is a 10 bolt ring gear with unknown miles but the gears look great.
I also purchased a Auburn posi unit for the 10 bolt pattern gears.
For those of you who have done gear changes, my question is: Is the only
difference between the 89-93 rears and 94-98 the ring gear bolts?
Are the carrier bearings the same size for all years? Pinion size?
I want to use the earlier 10 bolt carrier with all the parts from my 95 rear which only has
16000 miles on it.
