Strut Extensions
  • 73 Replies
  • 12514 Views
Strut Extensions
« on: January 21, 2006, 11:28:33 PM »
I'll be getting the steel on Monday, He
is going to start machining as soon as
I get it to him.
They are going to be 2-1/2" long to work
with the spring spacers that are available
from Digger.
I'm starting with 5 sets and I asked him
how much, trying to get the cost at about
$50 for the pair, but he said he would have
to see how long it takes to turn them out
This might be a prototype pair to start and
have them CNC mass produced to reduce
costs as well as increase production #s
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Strut Extensions
« Reply #1 on: January 22, 2006, 09:29:20 AM »
I'm on the list!
Offline da_tub
  • 307
« Reply #2 on: January 22, 2006, 02:26:11 PM »
are these for the older models, 89 and up? i could use a set.
91 four door ,and some stuff
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: January 22, 2006, 02:56:56 PM »
They'd work for all of them, 89-05.  They can all use the same shocks.
Offline da_tub
  • 307
« Reply #4 on: January 22, 2006, 07:32:44 PM »
oh sweet!! same thing i had in mind then ,, my buddy has a huge water cutter was going to get him to cut some for me ..
Offline the_maplebar
  • 466
« Reply #5 on: January 22, 2006, 07:51:25 PM »
So does 2 1/2" of steel make 1 1/2" of extension to the struts?  That's the size of Digger's spacers right?  If so I'm in.
« Reply #6 on: January 22, 2006, 08:02:15 PM »
No, 2-1/2" of length, the front is a compound
ratio, 2" at the spring is 3" at the wheel, but
the CVs can't take 3" without moving the axle
housing down, so 2-1/2" it is for CV life
Also, no upper mount flip is needed with these
Offline echojeff
  • 414
  • Lo que sea
« Reply #7 on: January 22, 2006, 08:51:10 PM »
So if with these extensions give you 3" at the wheel, do you need 3"spacers on the back and longer shocks to match?
I would be interested in a set. And the spring spacers to go with.
« Last Edit: January 22, 2006, 08:52:46 PM by echojeff »
95 Kick 4dr JLX.
« Reply #8 on: January 22, 2006, 11:46:39 PM »
Yes, here is my recommended list,
this one done for tracker_guy
http://www.zukiworld.com/forum/index.php?topic=10316.msg99079#msg99079
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: January 23, 2006, 04:29:07 AM »
Hey wild, I only want like an extension for a lift that is going to be 2" at the wheel.  Think your buddy can accomodate that?
  • 466
« Reply #10 on: January 23, 2006, 06:40:39 AM »
I second AJM's request.  I'm a little concerned that the 99+ model's can't go quite as far as the sidekicks.  They haven't been beaten on as much, and Calmini only does 2.5" instead of a 3".  So what do you think, do you want to keep them all of the same size or can we get some made that aren't quite as long?
« Reply #11 on: January 23, 2006, 07:56:19 AM »
I was going for max lift, but the change is
not a problem, it will be available either length
if that's what you want, I'll have him turn out a
set of 2-1/2" tonight, these are for my brother,
and a set of 2" after that, how many people think
the 2" is better suited for their rig ???
  • 466
« Reply #12 on: January 23, 2006, 08:17:12 AM »
I'm in for 2".  I'll be sending you an PM shortly.
« Last Edit: January 23, 2006, 08:24:09 AM by the_maplebar »
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #13 on: January 23, 2006, 08:21:54 AM »
I'm not interested, but I think 2" is better for the cv's
Offline bzzr2
  • 1011
« Reply #14 on: January 23, 2006, 02:08:31 PM »
also interested in 2 inch extension, even 1.5 inches might work better for my plans if that's a possibility.
09 taco reg cab short box 4x4
