Help with wheel sizes
  • 20 Replies
  • 3631 Views
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Help with wheel sizes
« Reply #15 on: January 12, 2006, 07:33:48 PM »
I like the 4" of lift and 31x10.5R15's on 15x7's idea.
Yeah, I am thinking that is about right...
ppltrak.. i will look in readers rides for your Track... if not there.. do you have photos?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #16 on: January 12, 2006, 09:47:42 PM »
I had 31x10.5's on 15x7 rims with a 2+2 lift and very minor trimming. I also had 33x9.5's on the stock 5.5" rims with the same lift. I'm also of the the opinion that first you work out what size tyre you want to run and then figure out how to fit it with the least amount of lift. For the ride I'm putting together at the moment I've gone old school with some 7.50x16's (mainly because I already had them and some internal pneumatic beadlocks to suit) on 16x6.5 Sport rims and the Calmini 3" suspension. They just sit inside the wheel arch. I don't need a body lift and only need to fold back the seam in the rear of the front well and remove the mudflaps from the rear. The steering stops will need the smallest adjustement as they just touch the chassis on hard lock fully flexed. The great thing about this for me is that with the factory rims and small lift it doesn't attract unwanted attention from the law.
With your 15x7's try looking for something with a -10 to 13 offset. I think the stock 5.5" are a 25P offset (1" positive) or 4.25" backspace although you may have variations in the U.S.
The 2" bodylift is nice and easy where the 3" requires a bit more fiddling around.
Think about your gearing too. With a 16v and auto with 5.12 diffs and 31"s the gearing was bearable but the 5speed suffers more. 31's seem to about the average limit (30's are definately easier all around) without to many problems, bigger than that is where more things are starting to get stressed and gearing becomes an issue and more cutting my be required.
Really it's going to depend on the type of driving you intend doing with it and what you don't mind changing and spending as to the final configuration that suits your needs.
Got to say with some decent rubber, locked and some t-case gears these rigs amaze a lot of people. Have fun.
Offline billybob
  • 23
« Reply #17 on: January 13, 2006, 11:26:32 AM »
Hey cj...
I might be a little late on the post but I feel that this is still valuable information...
http://www.daymotorsports.com/product/1307/c/1/
I'm currently using these with the 2" backspace on my sami and am very pleased... not only are they LIGHTER (~27lbs) than the american alloys they replaced but they're really affordable!! The downside is that they are not DOT... but hey who's gonna check that?? Been runnin 'em for 2 years now and satisfied.
L8R,
billybob_CA
billybob_CA
Offline cj
  • 1276
« Reply #18 on: January 13, 2006, 02:07:13 PM »
Hey cj...
Man, I hate it when a business can't even use the right terminology. If they don't even know the difference between offset and backspace what confidence does that give you  ??? Not only that , they then put misinformation in their FAQ.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #19 on: January 13, 2006, 03:01:17 PM »
Those wheels look like a bargain.. wish I could be sure of the backspace...
I might be going with Rockcrawlers after-all now.. not sure...
Going to stick the lift on, and go wheelin.. and see what I think..
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #20 on: January 13, 2006, 04:26:45 PM »
I dunno about those "light weight" steel wheels.  They look like the ones built for midgets and sprint cars.  Not sure if I want something like that under a 4x4 or anything I want to wheel and beat on.  Bet their load rating is pretty low.
Personally, when I get a different and/or bigger set of tires for the Tracker I'll put them on the aluminum wheels I have for it.  If only to save weight and make it that much more efficient.
