XL-7, Vitara/Grand Vitara snorkel group buy?
  • 40 Replies
  • 19616 Views
Offline jeffry
  • 87
Re: XL-7, Vitara/Grand Vitara snorkel group buy?
« Reply #15 on: May 10, 2006, 08:20:18 PM »
Wait till you see how fast you get too.  :o  My stuff shipped out and 3 days latter I had it.  I almost fell over!
George
No kidding, got it today - Order went through on Monday and got it Wednesday before noon. Absolutely amazing service.
Any tips for the install?
Again, Great find George.
Offline sergi
  • 307
« Reply #16 on: May 11, 2006, 08:21:20 AM »
I thought I had posted pics of mine, but I see I haven't. Here goes!
Margaret was also very helpful with us, service was excellent, and things got here really fast! They were sent on a Wednesday, and they got here next tuesday :o My model is slightly different, but I like it anyway ;D It's because packages can't be over 1m here, so they had to give me the shortest possible.
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline jeffry
  • 87
« Reply #17 on: May 12, 2006, 08:22:27 PM »
George,
What kind of time did it take to install the snorkel? I'm trying to figure out when to install mine, and just want to get an idea what it took you.
Thanks,
Jeff
Offline blacknight
  • 987
    • Gonzookin
« Reply #18 on: May 13, 2006, 05:36:57 PM »
3 to 4 hours but that was with a run to the store for a 3" hole saw.   Just take your time taking the fender off.  If its not falling off there's still a bolt holding  ::)   And don't lay the snorkel on the ground or it will scratch.   And remeber you only get to cut the hole once  ;)
George
Offline jeffry
  • 87
« Reply #19 on: May 15, 2006, 03:03:04 PM »
George, What was the reason to take the fender off? Or did you just take the inner lining off? I can't remember anything back there that seems like it would be in the way ... but, I obviously don't want to screw things up.
thanks,
Jeff
Offline the_maplebar
  • 466
« Reply #20 on: May 15, 2006, 03:09:32 PM »
Doesn't the air tube go between the inner and outer fender?  So it would be easier to line the snorkel up and attach it if you have better access.
Offline blacknight
  • 987
    • Gonzookin
« Reply #21 on: May 15, 2006, 04:33:05 PM »
thanks,
Jeff
You will need to take it off to put the new tube between the snorkel and the airbox.  Also you may need to pull the air box out too.
Offline jeffry
  • 87
« Reply #22 on: May 15, 2006, 08:30:31 PM »
Yeh, I got a few minutes and took the liner out and there is quite a bit behind there.
thanks,
Jeff
Offline nomaad
  • 179
  • I wanna go!!
« Reply #23 on: May 17, 2006, 09:26:33 AM »
Hey George,
Did you get your snorkel direct from FTS or did you get it through VTTR? I am confused?! ???
If from FTS can PM me the contact info?
Thanks in advance.
Offline blacknight
  • 987
    • Gonzookin
« Reply #24 on: May 17, 2006, 12:31:52 PM »
It's a FTS snorkel I got through VTTR  8)
George
Offline jeffry
  • 87
« Reply #25 on: May 23, 2006, 08:12:42 PM »
Snorkel installed! Very easy, for the most part, even though no instructions were included. It looks great and I added some 245/75/16s today. No rubbing with XL-7 rims (this is on a regular 4-door Vitara) whereas the stock rims and 235/70/16 ATs rubbed at full lock. Go figure.
Here's a pic, was hoping to get up on a trail today, but the driveway will have to suffice for now.
Offline blacknight
  • 987
    • Gonzookin
« Reply #26 on: May 23, 2006, 08:40:01 PM »
Looking good   8)  I will be hitting the trail this weekend with mine  ;D
George
Offline panos
« Reply #27 on: June 13, 2006, 12:55:46 AM »
Is it possible to have the contact info and the part number for the snorkel ?
Thanks in advance
Panagiotis
Offline blacknight
  • 987
    • Gonzookin
« Reply #28 on: June 13, 2006, 05:36:34 AM »
 Here the web site www.vttr.com.tw/e4X4.htm  If you want to  contact  them here's the e-mail address vttr.tw|removethispart|@msa.hinet.net atten.   Margaret.   Tell her I said hi.
George
Offline panos
« Reply #29 on: June 14, 2006, 12:08:15 AM »
Thanks George
