ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: dsumers on August 16, 2005, 07:12:08 PM
Title: What is the best power steering gear to run on the samurai with big tires?
Post by: dsumers on August 16, 2005, 07:12:08 PM
I'm in the process of another sammy build up.  I would like to hear some opinions on the best steering gear to run.  I'm using a high pinion dana 44 up front.  I have heard the kick setup is too weak. I've been thinking about using a saginaw.  I  will be running 35" or bigger tires, haven't decided yet.  Some pictures of stearing gears would be greatly appreciated.  Thanks
Title: Re: What is the best power steering gear to run on the samurai with big tires?
Post by: mrfuelish on August 16, 2005, 10:45:20 PM
some use ifs toyota, some fj 80 toyota, ect. get the arms from sky.
Post by: dsumers on August 21, 2005, 10:15:50 PM
I purchased a toyota ifs steering gear.  Does anyone have any pictures of install?  Is there anyone that makes a install kit?
Post by: explosivo on August 22, 2005, 03:15:27 AM
There are a few companies that make kits to install the IFS box onto a solid-axle 'yota frame that includes plates and sleeves. You could probably get one of those and make it work with the Tracker frame.
