ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Wene on May 07, 2018, 04:48:33 PM
I have a 93 sidekick 4 door, the entire fuel system has been replaced with the exception of the hose going from the filler neck to the tank and the fuel rail. The filler hose appears to have frayed edges causing a leak whenever i get gas. I'm trying to see the best way to go about replacing that hose but have not found anywhere with a made-to-fit part in stock or been able to find the specific dimension so I can get a length of hose to cut the length myself. I'd rather not have to take the filler hose off to walk in the parts store with it, since the sidekick is my only operational vehicle at the moment.
Thanks for any help
Try a search on megazip to find the part number. You can then search it to compare different sellers. I've used megazip for several items & have had good luck with them.
https://www.megazip.net/zapchasti-dlya-avtomobilej/suzuki (https://www.megazip.net/zapchasti-dlya-avtomobilej/suzuki)
Thanks, that is actually a lot of help for me finding other parts too.
