ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: Beagler on May 06, 2017, 04:04:34 PM
Title: Wheel stuck
Post by: Beagler on May 06, 2017, 04:04:34 PM
I have a 89 tracker that I can't get the front wheel off of. It has the alloy wheels and it is stuck. I have jacked it up and took the lug nots off and beat the crap out of it with a shop hammer and still no worky. Any ideas?
Title: Re: Wheel stuck
Post by: Beagler on May 18, 2017, 04:42:36 PM
 Anyone else ever have this problem?
Post by: beagle..t on May 18, 2017, 07:55:41 PM
nope ... if they are stuck I just kick the top and they fall off
Post by: fordem on May 19, 2017, 07:49:21 AM
I've had OEM steel wheel stick (on a different model Suzuki)  - the fit around the centre bore was so close that the slightest bit of corrosion would cause it to stick - a good kick would usually free it.
Try threading a length of chain through the spokes - if it can pass - and then loop the ends together and around a sledge and whack the chain - it should yank the wheel loose.
