ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: chevyate on August 19, 2015, 11:06:45 PM
I purchased these rods, to use as I managed to damage a rod in one of my motors.
They were packed in a nice sturdy box, that had multiple layers of foam, a sheet, then a layer with cut outs for two rods, another sheet, another layer with cut outs, then a final sheet. The rods inside are wrapped in oil soaked paper, which are inside sealed plastic bags. So the packing is very good, they came clean and rust free.
Link to AMAZON: http://www.amazon.com/dp/B00RYGIQ3G/ (http://www.amazon.com/dp/B00RYGIQ3G/)
(http://ecx.images-amazon.com/images/I/71Zy152XCML._SL1500_.jpg)
Fit for: Suzuki Swift Gti 1300 G13b 1.3L; Quantity: one set (4 Pieces), Center length: 120.00 mm, Big end diameter: 45.00mm, Small end diameter: 19.00mm
Forged SAE 4340 Chrome Moly Steel for the highest strength and durability, dedicated for Racing£¬Full 3D Designed and processed by CNC machine; All big and small ends are finished with SUNNEN honing machine;
Precision alignment sleeves positively locate the rod cap, maintaining big end bore size and eliminating cap walk; 100% X-rayed, sonic tested and magnafluxed, Multi-stage heat treated, Shot peened to relieve stress; Come with the bronzed bushing suitable for the floating piston pin; Weight tolerance each set rods: +/- 1g;
Come with ARP2000 bolts(contact us for extra cost for upgrading to ARP L19 bolts); Full covered by Manufacture Limited lifetime warranty
maXpeedingrods is also known as Maxspeedingrods
