ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: hwally on August 29, 2012, 07:43:27 PM
Title: Anyone out there with experience modifying a sidekick 1.6 to cv carb
Post by: hwally on August 29, 2012, 07:43:27 PM
I have the mods done as far as mounting the carb and installing a Samurai non-ecu distro.  I'd like some info on modifying the stock sidekick fuel pump.  I have an after market electric fuel pump but I need to hook up the inlet side to the gas tank.  Is it possible to modify the stock fuel pump unit so I can draw fuel from the tank?  Also on the Samurai distro.  it has two wires coming out of it  is one a ground and the other hooked up to the negative side of the coil?  Any help is greatly appreciated.
Title: Re: Anyone out there with experience modifying a sidekick 1.6 to cv carb
Post by: AZuki13 on September 04, 2012, 09:21:13 AM
The small ground wire on my sammy goes to the firewall. What carb are you running?
