ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: randy mohawk on July 17, 2012, 07:02:59 PM
Title: transfer case oil
Post by: randy mohawk on July 17, 2012, 07:02:59 PM
what is the best grade gear  oil  to use in a 4.16 transfer case?
Title: Re: transfer case oil
Post by: Jonny Rash on July 18, 2012, 07:04:51 AM
Just the standard gear oil, 80w-90.
Post by: kreator on July 18, 2012, 08:28:33 AM
80 / 90 with a gl4 / gl5 rating
Post by: mike5721947 on July 18, 2012, 09:20:09 AM
75-90 synthetic. i know my kick cant run 80-90 once it starts getting cold. had it happen in alberta where it was so thick in neutral it would stall the engine. but thats -20 -30 out...
Post by: ecoast on July 18, 2012, 11:05:11 AM
they say gl-5 ok  IF 'white metal safe'
Post by: fordem on July 18, 2012, 11:54:36 AM
Shouldn't that be "yellow" metal safe?
Some GL-5 oils use sulphur as an EP (extreme pressure) additive, and the sulphur can attack brass & bronze, which are yellow in color, hence the term.
Post by: Jonny Rash on July 18, 2012, 01:31:44 PM
You guys sure seem to be splitting hairs.   ;)
Just grab the gear oil from Wally World or your local autoparts store.  It will work fine and has been run in a 4:1 t-case of mine for 10+ years. :P
Post by: ecoast on July 18, 2012, 01:36:16 PM
yes, brain fart--lol
Post by: fordem on July 18, 2012, 05:54:40 PM
If the t/case is from a first gen trackick you can run what you want, if it's second gen it does make a difference - now - do you want to be the one wlaking into Autozone and asking for a "white metal safe" GL5?
Post by: Jonny Rash on July 18, 2012, 08:36:24 PM
4.16--> Samurai t-case
Post by: fordem on July 18, 2012, 08:43:22 PM
If I'm right the Samurai t/case has no synchros, so you'd be safe with a GL5 there too.
