ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: lilredsami92 on July 14, 2012, 12:00:27 PM
Title: 1987 samurai 5 speed trans problem helpppppp!!!!!!
Post by: lilredsami92 on July 14, 2012, 12:00:27 PM
ok so my sami will not go in to any gear with the motor on or off have no clue what it wrong pls help?
Title: Re: 1987 samurai 5 speed trans problem helpppppp!!!!!!
Post by: kbeefy on July 14, 2012, 12:18:41 PM
how sloppy is your shifter? I'd guess either a worn out/broken shifter+sheet(bushing) or something internal broken. Pull the shift lever and check it out.
Post by: lilredsami92 on July 14, 2012, 12:26:27 PM
it will go side to side but around 3rd and 4th gear it catches on something also i dont really kno what to look for
Post by: tuxblacray on July 14, 2012, 12:37:59 PM
This is most likely your problem and the cure....
http://www.zukioffroad.com/Tech_Library/transmission_shifter.shtml (http://www.zukioffroad.com/Tech_Library/transmission_shifter.shtml)
Post by: lilredsami92 on July 14, 2012, 12:42:15 PM
ok thanks ill be working on it again tomorrow so ill chech it out tomorrow
Post by: lilredsami92 on July 15, 2012, 10:53:28 AM
ok so i got it to go into gear but when i let off the clutch it doesn't move
