ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: kody on December 02, 2011, 11:24:21 AM
How do I tow a geo without engine or electric
With a tow Bar.
I have a tow bar. Do I need to disconnect anything on the geo
I would pull the rear drive shaft if your going long distance, but if you have a transfers case and transmission in it just take a strap for a motorcycle and pull the front of the trans up where it would normally be and put the transfer case in neutral and you should be OK I towed one like that for a couple of hundred miles.
