ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: trackerdawg11 on May 15, 2011, 09:37:31 AM
I have a 99 Chevy Tracker that is completely stock. The stock tire size is p205 75r 15. I was wondering if I could put the Super swamper SSR at 27 9.50r 15LT or the TSL Radial at LT 215 85r 15. I dont want to add any sort of lift, just a more agressive tire.
That tire would fit a stock Sidekick Tracker from the 89-98 era, so
if your wheel wells and arch's are similar they should fit
According to these calculators http://wildcatent.freeyellow.com/zookmods/calc.htm (http://wildcatent.freeyellow.com/zookmods/calc.htm) Your stock tire is 27.1 inches. So the 27 inch tires would be perfect. The 215 85 15 tire would be 29.38 inches. Hope this helps.
Ok thanks a lot I appreciate it!
