ZUKIWORLD Discussion Forum => Build Diaries, How-To, DIY => Topic started by: ghmikk on February 16, 2011, 11:01:16 PM
Title: Toyota 4.0 swap into a sidekick
Post by: ghmikk on February 16, 2011, 11:01:16 PM
I guess trying to be fast just got me into trouble.  It took some time to post this in compliance with the rules.
Title: Re: Toyota 4.0 swap into a sidekick
Post by: ebewley on February 17, 2011, 11:32:38 AM
http://www.zukiworld.com/forum/build-diaries-how-to-diy/welcome (http://www.zukiworld.com/forum/build-diaries-how-to-diy/welcome)!-please-read-before-posting/
Post by: ghmikk on February 17, 2011, 04:12:08 PM
This is going to be a tight fit. We are going to have to stuff this:
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8306.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8309.jpg)
into this:
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8308.jpg)
We made some progress today. We decided the first goal would be to hang the motor and tranny in the rig and see if we were really going to be able to make it happen. It made the motor look even bigger, but we could see potential.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8312.jpg)
One of our biggest obstacles is very clear, but we willl find a way to solve it.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8314.jpg)
We didn't really want to, but we decided that a little extra room would go a long way, and it would be best to do a body lift. Because the body is mounted with studs, We couldn't just throw any old spacers in there, so we made some to mimic the stock mounts, and put on the lift.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8316.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8315.jpg)
So after the lift, and cleaning up the engine bay some more, we took off the tranny, and did another test fit. We actually got the motor to sit in there low enough to work.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8318.jpg)
So we finished off the day with some engine mount prep, and will hit it again tomorrow.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8321.jpg)
Had another productive day. Eric came over in the morning to give us some help on the wiring. he got the rest of the old motor wiring out, and preped the body wiring for what we need to do. Thanks again Eric.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8326.jpg)
Then Drew got the rest of the brackets we don't need off the frame to clear up some room.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8329.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8328.jpg)
While this was going on, I got some motor mounts made up.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8325.jpg)
We also got some unwanted things like ABS out of the way, so we could start see how we are going to mount things like the new clutch pedal assembly.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8331.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8332.jpg)
We did some more test fitting of the engine. We ended up pounding back the sides of the tranny tunnel a little, pulling some steering components loose, repositioning a lift hook on the motor, and removng more brackets. At the end of the day, we got the motor with the tranny sitting exactly where we want it to be. It all fits, the shift lever for the tranny lines up perfect in the stock position, we have solutions for all of the interferance issues with suspension and steering components, and it even looks like the hood might close without altering it. All in all, it was a very productive first weekend of the project.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8333.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8335.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8340.jpg)
found a radiator out of a 1990 t-bird super coup that is going to fit very nicely and was way less than a custom size. Yesterday i got another transfer case and greg and I took them all apart and decided that there were enough bearings that looked suspect we should put a rebuild kit in while it's all apart. Right now we are waiting for parts, we don't want to build the cross members until we have the headers and they won't be here until thursday or friday which is when we also get the transmission to t-case adapter, t-case output shaft and the t-case rebuild kit. Brian is helping with the wiring harness, he was able to get all the wiring diagrams we need from his work and I dropped the wiring harness off to him last night and he is going to start looking it over. If all goes well this weekend we should have the engine mounted with most if not all the cross members built, headers on, t-case's in and mounted and maybe even the radiator in. I can't believe we have come so far so quickly!!! Greg is an amazing mechanic and fabricator!!!! (and fun to work with also!!!) It looks like we are going to be able to use the complete FJ hydraulic clutch pedal assembly and the gas pedal will be easy since this is a drive by wire system. The transmission couldn't have lined up any better if we had had it custom built but I think that some of the t-case levers will be in the way of the e-brake handle. Hopefully we will be ready for exhaust and drive lines by next week!!
Post by: ghmikk on February 17, 2011, 04:14:24 PM
So.... Thursday we got the rest of the Tranfer case adapter parts, so Friday night and today, it was time to do all the transfercase work. We put a lot of new bearings in, did some modifications, and got the cases together, with the 4.7's in the rear, and an upgraded rear output shaft.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8344.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8345.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8350.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8348.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8347.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8346.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8352.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8351.jpg)
So we married it up to take a look at it. It looks really long, but the rear flange is only 8 inches further back than the stock drivetrain, so it will work well. To finish the day, we started working on some mounting brackets will tie the tranny and transfercases together.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8355.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8357.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8356.jpg)
I still haven't gotten my headers... I've called both URD racing who I bought them from and Doug Thorley and have been assured that they will be here by the end of next week but I've heard that twice already. We are hesitant to actually mount the engine with out them as it would really suck to have to rebuild something for a small amount of clearance. There are enough other things to do to keep us busy for this weekend but I really hope they come by next weekend!!!
Wow, another good weekend!!! We got lots done but aren't quite ready for exhaust and drive lines :0) The belly pan and brackets are looking really good, they are going to do a great job of protecting everything. We will add cross members to them once we get the headers and do our final fitting. After getting the fab work as far as we could we started in on the steering. We decided to move the power steering gear box into the frame and take out the slight kick that is factory, the back of the gear box originally points kinda towards the passenger seat as opposed to straight back. After our modifications it will point straight back keeping everything as tight to the shock tower as possible. We ran out of time and energy before getting this all done, but we now have it all figured out and are ready to start re assembly tomorrow night. It was a good weekend and the silver lining of not having the headers is that we don't feel rushed into putting the engine in and can spend a little extra time figuring out all these little details and designing/fabing our parts and pieces. I've made an appointment to get the exhaust done for a week from Monday, I think we will make that time frame if the headers get here by the end of the week. If not I guess I will be rescheduling!
Here are some pictures from the weekend. Here is the bracket that is the start of the T-case mounts. It bolts to the transfercases and the transmission so it will help take some of the stress off of the adapter plate.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8359.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8360.jpg)
Here is the skid/belly pan that will tie everything together for strenght and protection.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8361.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8362.jpg)
And here it is mounted.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8364.jpg)
Here is the steering relocation project. We removed the mounts and made room in the frame. When it is all done, the steering box will leave plenty of room for the motor.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8367.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8368.jpg)
We definitely upped the thinkness on the top edge, on top and out the outside, with all the layers, it is at least a half inch thick. It is plated from the shock tower to the front of the fram on the outside, top and bottom. I didn't see any cracks, but it did have extra plate added from before. The "new" plate is the old double thinkness inside piece of the frame, so the "tubes" are threaded all the way through, so the bolts tighten flush to the mating surface, and the are securely welded to the outside wall of the frame, for extra strength. There is enough steel in there that is should be alright. It is not as pretty as I would like it to be, but it is solid. Here are some pics.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8376.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8375.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8373.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8372.jpg)
The goal this weekend is to have motor and tranny mounted in the rig, and by the end of today, we almost have that done. The motor is in the position it is going to be mounted and the tabs are tacked in place, ready to be welded up. Most of friday night and today was spent getiing surfaces ready and making brackets and tabs. First Drew got the frame all cleaned up and ready. You can also see in the picture, thet he put up some heat and accoustic sheild in the engine bay.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8379.jpg)
didn't get a ton of pictures of everything we accomplished, but I will get some more tomorrow. Here are plates to go on the frame for the motor mounts.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8380.jpg)
And here are some of the motor mounts
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8386.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8384.jpg)
And here are some of the transfercase mounts
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8388.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8381.jpg)
And here is the last one after it was all cleaned up.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8390.jpg)
Post by: ghmikk on February 17, 2011, 04:15:50 PM
So, another busy weekend has passed us by, but more good progress was made. Right now, the motor is sitting in the rig, in the motor mounts. We still have some work to do on the mounts, but the majority is done, and we have a clear exact plan of what we are going to do with the oil pan, and the suspenssion to make everything clear. Here are a couple of pictures, hard at work:
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8398.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8400.jpg)
So here is a picture of all the pretty heat sheild and the start of our motor mounts. We decided to run a cross bar between the motor mounts under the oil pan, so we could tie every thing together, since those mounts are on the frame in a high stress area. Under the motor is about the only place we have room. Drew decided to go for the air conditioning, so with the compressor back on the motor, it makes things a little tighter in there. The only down side to our motor mounts is there size. We had the motor, tranny, and transfercases all together when we tacked all the mounts to the frame, and we had been pulling the motor and tranny in and out together, but we discovered that with the mounts in there, the oil pan will not come past the mounts. That means we have to pull the tranny in tight quarters, so we can lift the motor straight up. Not a huge deal, just more work to get everything apart.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8406.jpg)
Here are some better pictures of the mounts tagged on.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8407.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8408.jpg)
So we really wanted to make sure we don't have any problems with the high stress area of the frame, so here are some of the plates we have added, We ran another plate from the motor mounts over the crumple zones into the steering box area, and then also put a plate between the panhard mount and the motor mount to tie it all together. we are still going to add some more brace on the underside to the panhard mount, but I don't think it will be going anywhere.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8415.jpg)
A decent amount of time was spent finishing our transfercase mounting bracket, that also bolts to the tranny. We wanted to make sure it cleared everything, wasn't too heavy, but was still strong. I think we came up with a decent design. I wish I could have gotten the junction over the front driveline to look a little better, but it was starting to get a lot of time into it, and there wasn't al lot else to do with it. We also ended up making the rear mount able to comes off, by making a solid piece that goes inside the tube. We decided to this after we tacked it all together in the rig, and then had a hell of a time getting the thing out of there. Here is how it turned out.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8416.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8418.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8409.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8410.jpg)
At one point, Drew started cleaning up the engine bay while he was waiting for me to finish what I was working on and get done with the welder.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8419.jpg)
So here it is, the motor sitting in the rig, all it's weight on the springs, in the mounts. It really didn't make it squat that much.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8420.jpg)
It is definitely a tight fit, with no room to spare, and no extra space to give away. It will all clear however when we are done, without having to do anything too crazy. We will be moving the top link, and slightly modifing the sump on the oil pan. The way it measures out right now, at full compression, the third member and the sump will interfere by a half an inch. So after the link is moved ( right now it hits the new cross member before full compression ), we will pull the springs and let it sit on the bump stops, and then make our oils sump fit the space we have.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8421.jpg)
For the last thing of the day, we tried to see if the hood would fit. We had to cut a couple braces, but it just wouldn't quite close all the way. just three quarters of an inch shy. We really just could't put that motor any lower, so the hood is just going to have to get modified.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8424.jpg)
Wow, some of the cowels and hood scoops are pretty over the top!!!! I found one that I think will work: http://www.summitracing.com/parts/SSE-950-72103 (http://www.summitracing.com/parts/SSE-950-72103) I think that it is about as low key as they come. I'm hoping to go and get the AC from jared tomorrow so there is a chance that we can get that installed before putting the engine in for the last time. I had to bump the exhaust appointment out for a week as I didn't want to be rushed tying up all the loose ends. I canceled the header order and have reordered a different set of headers which are shipping today and will be here by the end of the week. There is a chance we won't be able to fit them, but if not we have verified that the stock manifolds will work. We took some rear drive line angle measurements and it's looking like we are only going to have a 17 degree angle at for the rear drive line, not nearly as bad as I had feared!!! The transfer case bracket that Greg made is a real work of art, the pictures don't do it justice!! we had it laying on the floor and even with Greg jumping on it there was almost no flex!!! We are going to be pulling off this project for the rest of the week as Greg needs to do some work on the sub but we will be back on it Friday night!!!
Post by: ebewley on February 17, 2011, 05:22:36 PM
Thank you for bringing it over... The swap is looking good!
Post by: BRD HNTR on February 18, 2011, 07:06:17 PM
That is great work.  That doubler is going to really make this build.  Looking at your wiring(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8326.jpg) makes my head ache again.  Glad I didn't have that many wires to get right.
With headers I imagine you are going to have duals, so while it is empty under there you might modify the cross tube to make room for the other pipe.  this is what I did.
(http://lh3.ggpht.com/_86HP5-adsWc/THhEVtnsCuI/AAAAAAAAIBQ/YsYGrcQBHUg/s800/DSCF0008.JPG)
Or did you have to remove the cross tube for the doubler?
i would like to know the length of the doubler from front to tail shaft.
Post by: ghmikk on February 20, 2011, 02:21:22 AM
We just took the tube out all together and will do something different.  The rear flange on the case is only about six inches farther back that what was in there stock.
Here are the latest notes:
I had to work this morning, so it was Drew by himself till this afternoon, so it was a little slower start to the day, but by the end, we got a lot done.  The goal by the weekend is to have the motor, tranny, and transfer cases in, and the suspension for the most part done.  The first thing to finish was the rest of the gussets on the motor mounts and some clean up in the motor bay.(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8445.jpg)
Added a little beefier brace to the panhard bracket.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8456.jpg)
Drew finish cleaning up the lowered shock tower baskets.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8442.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8443.jpg)
Drew also got the new clutch pedal assembly mounted.  It worked out pretty nice with it being a complete unit with the clutch master cylinder.  We may have to lengthen the clutch pedal, but even as it s, it would work.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8453.jpg)
the lines in the engine compartment are made and run.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8446.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8447.jpg)
We also made a short hard line and bracket to go on the transmission.  This makes only one last joint to screw together after the tranny is in.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8457.jpg)
Next up was the suspension.  There is a lot more room to work on it with the motor out.  We got all of the old brackets cut off of the axle, and everything cleaned up.  We are going to move the upper link rounf eight inches to the driver side so it will miss the oil pan.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8459.jpg)
We got the main crossmember off, and moved the mount over and welded it back up.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8458-1.jpg)
Then we started cutting out the plates to build the new front mount, and this is where we ended for the night.  We'll get pictures of those tomorrow.
Post by: joshembry on February 20, 2011, 08:45:47 PM
that wiring picture made my brain hurt
Post by: SamuraiGuy on February 20, 2011, 09:46:01 PM
The part on the passenger side looks like something out of Labyrinth.
Post by: Jluck on February 22, 2011, 08:12:58 AM
thats just funny! :laugh:
glad too see this build on zukiworld. I can come do the plumbing if your working on it today.
we could rename this build......maybe 10#'s of potato's in a 5# bag? or shoehorn sidekick......
Post by: ghmikk on February 22, 2011, 09:59:35 PM
It does need a name like that.  It is definitely a tight fit.  I used to think front wheel drives had no room, now they seam roomy.  Everything is right down  the abslute minimum for clearance.
Post by: ghmikk on February 27, 2011, 08:54:09 PM
We tackled a lot of problems and made a lot of progress today. It was really exciting to see everything turning out so well. We startedout where we left off and finished cutting, fitting and welding up the new link mount. It turned out being a really nice looking bracket.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8460.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8462.jpg)
 So then we got it burned onto the axle.  Before we even pulled the top link, we got the angle of the axle measured, and held in place.  At first we left the link the same length.  In it's old position, it ran at a slight angle, now it ran straight, so it was long enough that it pushed the mount too close, or into the panhard bar, so we had to shorten it up to be able to get the right position.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8466.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8465.jpg)
About the time we decided to weld it on, we also pulled the springs out so we could run the suspenssion through it's full range of motion.  In the new position, everything was working great, and then.........
We ran the suspenssion up to fully compressed, and then noticed we had an issue.  It was hitting the crossmember we added under the motor.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8470.jpg)
So we had to cut the top of our pretty new bracket and modify it. We managed to push the top plate down so it is reccessed in between the front and back plates.  Now the crossmember fitts down into the bracket, so it will only touch if the bump stops are fully compressed.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8475.jpg)
Now it was time to put the motor in and run the suspenssion and see how bad the clearance issues were going to be.  Amazingly it really wasn't bad.  The drag link cleared, and th panhrad just barly touched, so we will only have to put a couple of degrees of bend in it, and the oil pan had more room than we thought.  We only had cut one corner of the pan and change it, and we didn't even had to change the pickup tube.  We gave the pan just a little clearance, so there is just enough room.  Jared also can by during the day and gave us some better solutions for running the heater core lines, thanks again!
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8477.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8480.jpg)
While we had the motor in there, we started checking for other possible issues, and we tried to get the headers on.  There wasn't enough room to get them on while the motor ws in, so we pulled it and put them on.  After putting the motor back in, it wasn't looking good.  They were against the steering, and everthing else on the other side.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8478.jpg)
We looked or possible solutions, and finally went with one.  I wasn't sure I really wanted to do it, but we changed up the steering.  Everthing was beefed up as much as possible to avoid any failures, and it actually turned out alright.  With another test fit, we had the room we needed.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8483.jpg)
on the other side, we moved all the fuel and brake lines to the top of the frame, and also got them up against the fender.  It got them nice and out of the way.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8482.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8481.jpg)
We also got the transfercase mounts all welded up, so now we are pretty much ready to put everything in.
Well, it's in there.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8496.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8495.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8492.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8493.jpg)
Post by: ghmikk on February 27, 2011, 08:56:19 PM
We had a good day of finishing up some little details. Greg was able to get all three transfer case shifters up through the stock hole with enough room to work them all. He also got the short shifter installed and the gear box shifter installed. We got the intake figgured out and the mass air flow sensor installed. Brian came over and started working on the electrical, we got the ECM mounted, the engine wiring through the fire wall, and have made provisions to redo the existing fuse box as it went where the new clutch pedal currently resides. We got the radiator in, hoses on, fan in place we just have to modify one bracket to finnish that off. The power steering is 100% done. We pulled the belly pan and decided to make another piece of armor for the oil pan that will bolt to the belly pan, we also want to check clearances between the belly pan and the top front link, may have to do a slight mod there. We hope to be done with everything but electrical by the end of today!!! Brian wasn't sure when he was going to be able to come back but I think that we will be able to fire the engine next time he comes by! Greg has some pics I'm sure he will post soon.     ~Drew~
So here are some pictures to go with Drew's progress report:
For starters, here is the new driveline. Just going by the weight, I feels lik it is more solid than his links.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8497.jpg)
And here are some pictures of the exhaust that was done this week.  It is really tucked up nice and tight,
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8504.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8507.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8503.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8502.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8501.jpg)
For the shifters, we rebent the twin sticks, and added some to the stock shifter for the front case.  They come up in a nice tight little cluster through the stock hole, with just enough room to be able to use them.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8514.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8513.jpg)
And here is the cold air intake we made.  We made a plate for the sensor, then cut a hole in the pipe, and sealed it up.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8515.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8518.jpg)
So here is some more pictures from our progress this weekend.
Here is a picture of the radiator in it's final mounted position,  It is really tight with the fan behind it, but there is just enough room.  We had to trim the back of he grill just a touch, but it is going to work good.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8520.jpg)
The power steering lines are run across the front and finished.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8548.jpg)
Here is the wiring harness through the firewall, and the heater lines run, and the fuels lines run.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8549.jpg)
Found a nice spot where the new ECM fits and Drew made a bracket to mount it with, so here is where it will live.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8522.jpg)
Ended up moving the fuse block because of the clutch assembly being in the way, so it moved to where it can be accessed though the speaker panel.  We also got some help going through the process of figuring out this mes of wiring, and got some more stuff labeled.  Thanks Brian.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8552.jpg)
We pulled the springs again and checked for clearance with the top link and the belly pan.  It doesn't clear by much, but it clears.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8531.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8534.jpg)
While we where at it, we got the panhard arm bent so it clears the motor.  We also got the drag link to the right length to the steering is all set
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8547.jpg)
We also made a small skid plate for the oil pan, just for extra precaution.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8539.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8540.jpg)
We have a check list going, and it is getting Smaller fast.  The goal is to see how this week goes and work toward getting this thing done next weekend.
Post by: Jluck on February 27, 2011, 09:30:18 PM
friggin sweet! I wanna ride! ;D
Post by: TrakJD on February 27, 2011, 11:33:28 PM
That picture with exhaust pipe and shock.  I know pic doesnt do justice but it seems like they are barely touching eachother.  Otherwise, everything looks good!
Post by: Jluck on March 12, 2011, 09:04:41 AM
i'm looking forward to seeing this thing tonight ;D hopefully get a ride in 'Er too!
Post by: wvscotsman on March 12, 2011, 03:15:51 PM
Thing is going to be a beast. Damn nice write up. Keep up the good work.
Post by: Jluck on March 12, 2011, 03:21:26 PM
it's done and on the road! I might get a ride tonight  ;D
Post by: wvscotsman on March 12, 2011, 04:19:41 PM
WOW you guys knocked this project out pretty fast. Cant wait to hear how she runs.
Post by: BRD HNTR on March 12, 2011, 04:26:04 PM
YES, lets see some pictures, and hear it run.  That was one fast build.
Post by: Jluck on March 13, 2011, 08:49:56 AM
its one fast kick too....wow....power and torque up the a$$! :o ;D :o ;D
I busted his chops a little bit about getting a finish post and maybe a vid up here too.
Post by: ghmikk on March 13, 2011, 09:50:52 AM
I was going to try to post the rest of the pictures and update the build thread this morning, but I don't have time.  I will get it posted u this afternoon, I promise.  I don't have any video of it yet, but I will try to see if I can get some this week.
Post by: Drew 4.0 on March 13, 2011, 12:11:23 PM
Well, I finally took the plunge and signed up on this site.  Just wanted to say a huge thanks to Greg for all his help, use of his shop, tools and expertise to get this project done.  This has been a fun project that has turned out really well and been done in a very timely manor which was important since this is my only daily driver.  As of now things are all working great, this engine swap has transformed this sidekick and made it so much nicer to drive!!!  I still have to find an AC condenser and get some lines built before the AC will work, the cruise control isn't hooked up yet, I need to find a switch that will work with the toyota ecm, I'm going to try using a stock sidekick one first if that doesn't work I'll have to go after market.  I just got the signal converter for the tach yesterday, I hope to have that in soon so my stock tach will work and then sometime this week I'll be getting an extention/adaptor for the sidekick speedo cable so that it will work with the toyota transfer case.  And then last but not least I need to get the cowl on my hood to cover up the hole we had to make in the hood.  Considering the size of this project these are very minor things that I can easily do while driving the rig.  There is no way that this project could have been done with out all the help and advice I got from friends and the Mid Valley Crawlers club, Greg by far spent the most time helping with all the fab and instilation, Brian did the wiring harness, Eric helped remove the old wiring and ecu, Jared helped with his fancy hose clamps and hose adapters, Davey came by and spent a few night helping, lots of good help!!!  Thanks to all!!
Post by: ghmikk on March 13, 2011, 11:48:01 PM
Well I finally got the rest of the build diary and pictures off the other site, so here it is.
Joe Posted 2011-02-28 5:10 P
What kind of bump stops is Drew running? One mistake I made on my 4runner swap was under estimating how much my bump-stops would compress. They squish about twice as much as I thought they would, and I was smacking the steering link into the frame during hard compression. Its fixed now but was an annoyance. It just reminded me of that as I looked at your TIGHT tolerances! I was in the same boat (suspension wise)
Drew   Posted 2011-03-02 7:15 AM
I don't have bump stops, just the rubber ring on the top of the shock, I've never bottomed out the suspension before but if I find this is a problem I will add bump stops later. I'm hoping to revamp my suspension at some point, right now my drivers side front shock is totally shot, we have to use a digging bar to pry it out of full compression. I'm going to save those things for another day, right now I just want to see this thing up and driving!!!
Drew   Posted 2011-03-03 10:47 PM
Got the whole front end all put together, all my goodies are in under the hood, air compressor, winch controls, etc, got the front bumper and winch on, had to make all new mounting brackets as it looked dumb sitting low because of the body lift. Brian came over last night and lined me out on some wiring, got it all done today with a few exceptions. I got my rear drive line on, we had to modify the rear output flange on the t case to take a 1350 cv but it all works now. I built a battery terminal that I can mount on my fire wall and it gives me 6 additional 5/16" studs for mounting big accessories and I'm going to put a bat disco on b4 it so all accessories can be turned off with one switch. I'm also adding two 10 spot fuse box's, one will be constant power, the other will be ignition power for adding smaller electrics later. I really REALLY hope that tomorrow is the day we get it started, send good thoughts my way!!!
Drew   Posted 2011-03-04 6:01 PM
Well, it turns over great, and even tries to fire with some starting fluid but we never did get it running. After doing some testing with a fuel pressure guage the most we could get was 20 psi so we think that there just isn't enough fuel pressure to start. I found a 70 psi inline pump that I will get tomorrow and really hope that it will solve the problem. Talking with Brian he said that only having 20 psi might have been why the 16v never wanted to start right away, I guess we will find out when it goes in Davey's sammy with 90 psi!!! Thanks for the moral and tech support Davey, Brian, Jared and of course most of all Greg I think that we are in the home stretch!!
ghmikk  Posted 2011-03-06 11:40 AM
It runs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! With no major error codes on the computer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! We are going to test drive it in a couple minutes!
It's not as fast as a sports car, but is really fast for a wheelin rig. It has got some really nice power now. Here are some pictures from this week:
When we first started to really put things back together, the bumper just didn't look right being low, so we had to build some new brackets to raise it up,  Drew didn't like the big open space in the bottom, so he added some expanded steel to help protect the radiator, it turned out really good.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8553.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8557.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8555.jpg)
The wiring took a while to trouble shoot.  At first, it was a power wire for the injectors that was missing, and then this morning, we found the same problem to power the coils.  All problems are solved and everyting is happy.  This was with everything hooked up.  it got cleaned up a little more before the dash got put back.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8561.jpg)
Here was all the new fuse blocks and relays that drew added
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8558.jpg)
There is a lot of stuff under that hood.  Here is all the other goodies all installed.  The power block behind the battery that Drew made turned out really good, nice clean place to hook everything up.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8559.jpg)
Everything put together but the grill
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8560.jpg)
And here it is after a test drive.  It has a mud flap uver the motor to keep everything from just being out there.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8568.jpg)
That thing turned out so awesome. The gearing is so low, it will power brake at idle. It is also crazy how little the motor and transmission move, it fact it is hard to tell if they even move at all, no matter how much torque they take. That really helps with the tight fit, because there is not much room for the motor to move. There are still a few bugs to work out, but it is on the road again
Post by: ghmikk on March 13, 2011, 11:50:38 PM
 Posted 2011-03-08 12:12 PM
So far there is only two bigger issues. One was the driveline, it had a lot of vibration, and jack up and turning it looked quite a bit out of center, so it got taken back. Sounds like a new guy that they thought was capable of building the driveline, appearentlt was not capable, and they were imbarrased to say they touched it. The other was play in the rear output of the transfer case, and the bearinf is too loose of a fit in the rear housing. So hopefully all the parts will get here in time to be able to drive it to the meeting.
 Posted 2011-03-08 5:52 PM
This has been a fun build to take on. It is giving me lots of ideas for my sidekick. Today, Drew Talked to Marlin today, and they said they had a bad batch of tail housings, and thought they had caught all of them, so it sounds like we got one of the last bad one's. They are overnighting a new one, so that problem is solved. The driveline came from Dallas custom machine. It was a new guy that still kinda learning. They thought he knew enough to do it on his own, but from the sounds of it, they were wrong, and won't be doing that again.
Drew  Posted 2011-03-09 10:23 AM
The beast lives!!!! I still haven't gotten the smile off my face :0) all the little odds and ends are coming together nicely, I'm getting everything just the way I like it. Yesterday I got the overflow tank mounted and plumbed, the third fuel line plumbed, my gauges mounted properly (and yes I changed out the plastic oil pressure hose for a copper on Jared). I have a signal adapter I got off ebay coming that will make my stock tach work and I'm talking to a shop in portland that will help me get the suzuki speedo cable to work in the toyota transfer case. I've still got a few things to do like re-wire my remote winch control and I have a plug that got buried in my dash somewhere that I need to find to make the air compressor work. I don't really have any extra money to spend right now so I'm not going to be doing much to the front suspension, I just ordered a replacement shock for the one that is blown so I can drive it for now. I'm just waiting for the new rear housing to show up then I will be heading over to gregs to install it and hopefully drive it to the meeting!!!
Posted 2011-03-09 3:39 PM
So close, but so far away. Got the new tail housing and driveline, put everything together, and that solved those two problems. Now there is a loud noise coming from the bell housing that keeps getting louder. Soooo, it is not going to make it to the meeting. We will be pulling the transmission tonight after the meeting to see if we can get it on the road tomorrow.
 Posted 2011-03-10 1:24 AM
Well, the transmition and tranfercases are pulled, problem is fixed and the transmition and transfercases are back in. Just crossmembers, drivelines, clutch to bleed, and belly pan to put back. Turns out the problem was all of the crankshaft bolts backed off, and the flywheel was starting to chatter and come loose. We caught it before it did any damage, used locktite, and torqued everything down real good. I don't know if they really got torqued the first time, but they are now. It will be back on the road tomorrow, and should finally be all road worthy and ready to be driven.
Drew Posted 2011-03-10 6:58 PM
Well, things are super awesome again :0) It was my fault that the fly wheel didn't get torqued, I took it off and had it machined and then put it back on (at least most of the way) and then got sidetracked by other things and totally forgot that I never torqued them, I think I meant to look up the specs and then just plain forgot... I think that the speed and ease we were able to take it all apart and put it all back together with all the parts and pieces on the car is a real testament to Greg's foresight and ability to fabricate things that work well, are built strong without over kill and can be worked on and added to. In taking everything apart last night I don't think there is one piece or part that I would change, to get that much motor, tranny and 2 t-cases into that little of a pakage and still be able to change the fly wheel in less than 6 hours is nothing short of an engineering marvel!!! And to think that there was no fancy auto cad designed laser cut pieces just makes it that much more impressive. Out of the 3 mistakes that have hindered this project Greg is responsible for none of them but he still fixed them all with a smile and a shrug. Bottom line: GREG IS THE MAN!!!!
Posted 2011-03-10 10:02 PM
Thanks Drew. Here are some pictures of playing around and testing this afternoon.
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8570.jpg)
(http://i284.photobucket.com/albums/ll18/ghmikk00/IMG_8571.jpg)
Drew  Posted 2011-03-11 5:19 PM
Well, I want to make sure there are very few surprises left under the hood before I go to far. But I've got the bug BAD!!! I can't wait to get this thing on a trail :0) There has been to much time wrenching and not enough time wheeling!!!
I just got my new front shock and put it on, it helps and makes the ride and handling way better but my drivers side front corner still sits low, I think that I've done some damage to that coil running it so long with a bad shock. I still barely bottom out when going over speed bumps evenly with both front tires at any speed so I ordered some new 16" heaver rate coils my old coils were 14" with a one inch spacer, I'm hoping to loose the spacer and get a little more up travel without lifting the front to much. Right now it feels like when it had the softer springs up front that came with the trail slayer kit, I hope that stiffening them up will get me back to where I was before the engine swap. Brent is now putting 16" coils with all the new trail slayer kits, I think that is a good move on his part and will make the kit work even better than it already does.
Well, I just completed my first kinda long distance drive, ran up to portland today for the 4 wheel drive place thing, that was a waste of time, no ramp, no food, no cool cars, but I did get a free shirt... The way the sidekick drives now is soooooo awesome I can't even explain, it is night and day difference!!!! At highway speeds it is quieter than before, still not silent, but way better, there are almost no vibrations, tons of power, and with the soft springs up front it rides like a cadillac. I finally got my GPS in and was able to do a MPG test, right now I'm only getting 17, not terrible, but not great either. I looked into the stock gearing of the FJ and they ran 3.91 axle gears and I'm still running 5.71's. First gear right now is super low, I can start in second no problem and third ok. I think that when I regear my mpg will go up a bit, I haven't gotten my tach signal converter but I would guess that I'm turning 3.5k - 4k at 65 -70. Just when I think that I couldn't possible like my car any better I find out just how nice it drives on the highway and fall start likeing it even more, when I get the springs set up right, it re-geared, AC blowing and the cruise working this is going to be the ultimate long distance exploration rig, at least in my opinion :0) Greg really is the man, have I mentioned that before?
Post by: BRD HNTR on March 17, 2011, 06:24:13 PM
Looks like lots of articulation.  Took a lot to get that rear tire off the ground.  I would like to see that doubler sometime, so if you ever run up North, let me know.
(There is always something to make it a little better.)
Post by: Drew 4.0 on March 18, 2011, 03:54:47 PM
I have family up in Washington so I'll see if we can meet up next trip.
Things are finishing nicely, I've gotten new front springs, they are a bit stiffer and work much better.  My tach signal converter is in and works well.  I've had the speedo working twice, but I'm having an issue with the speedo cable breaking right behind where it plugs into the cluster, I think that I might have a bad speedo, this is a new (to me) cluster because my old gauges had some issues.  For the little bit of time that I've had it working I can tell a huge difference in how the engine runs, I think that there are different setting the computer uses for running the engine based on wether its sitting idling or if it's driving, I think that my milage should improve a bit just getting the speedo working, at least I hope :0)  We were putting a tranny in LocJaw's nice 4 dr kick and I noticed that he had cup holders in his center console so I checked into the cost through suzuki to get one and it was only $46, so I've got a sweet new center console coming, I can't wait to have cup holders!!!  I've been slowly working on sound proofing the interior and got the back mostly done, I think that to do the rest I'm going to have to pull the seats so I might wait until I've got the new console and do that all at once.  I'm ready to do my first big fluid change and have decided to go with Royal Purple, I've got it all ordered and it should get here soon.  After getting that done it's going to be time to hit the trails!!!
Post by: bentparts on March 19, 2011, 10:00:22 AM
Sweet build, you guys did a great job. wish I had friends with skills like that!
Post by: Jluck on March 20, 2011, 10:10:36 AM
heres a couple "in action" pics.
Post by: Drew 4.0 on March 20, 2011, 11:59:07 AM
Thanks for posting the pics!!!  Man, it felt like I was at a much steeper angle on that tree, should have kept going...  Tatiana and I had a really fun day, thanks so much for letting us tag along we hope to do it again sometime soon!
Post by: KJMac on October 25, 2011, 10:30:19 PM
Is drew from Dallas? I think my brother lived on his street at one time.
Post by: airmanwilliams on November 07, 2011, 08:36:50 PM
AWESOME build. thank you for sharing the link on expoditionportal.com so I could follow.
Post by: Warn Industries on November 10, 2011, 08:43:19 AM
I agree: Awesome build.
- Andy
Post by: JDMCRX on March 17, 2012, 08:08:30 PM
Awsome build any vids ?
