ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: susan_4X4 on August 16, 2010, 06:54:24 AM
#1. Strengthen Trackick Front Differentials With Overhaul:
http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm (http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm)
#2. Strengthen Trackick Front Differentials With Calmini Anvil Front Axle Housing:
http://www.puresuzuki.com/anvil_axle.htm (http://www.puresuzuki.com/anvil_axle.htm)
#3. However, Calmini does NOT tell you that you ALSO need 26 spline differential side gears AND two 26 spline short axel shafts PLUS New Axle Output Shaft Seals PLUS New Axle Shaft Seals PLUS New CV Joint Boots!!!!
Topic: fixing the track/kick front housing BEFORE it breaks...
http://bbs.zuwharrie.com/content/topic,100689.0.html (http://bbs.zuwharrie.com/content/topic,100689.0.html)
You can also just pick up a Samurai steel diff and put the 5.12 gears in it. Then you can use the side gears required for your year, 22 or 26 spline.
An alternative to the Anvil is to build your own from a Samurai rear end.
#1. The following article gives the wrong URL for Randy's Ring and Pinion!!:
#2. The correct URL for Randy's Ring and Pinion is!!:
http://www.ringpinion.com (http://www.ringpinion.com)
http://www.ringpinion.com/Contact.aspx (http://www.ringpinion.com/Contact.aspx)
Sales 866-631-0196
Customer Service 800-292-1031
Online Customers 800-347-1188 Ext 5504
To be fair, the link was correct back when the article was posted over 7 years ago. :)
Whitfield replied at the following URL:
Great info -- Thanks for sharing... Also, if you find a late model Grand Vitara 5 speed 4wd -- some of them have steel housings that will swap in.
http://bbs.zuwharrie.com/content/topic,111661.0.html (http://bbs.zuwharrie.com/content/topic,111661.0.html)
[url]http://www.puresuzuki.com/anvil_axle.htm[/url] ([url]http://www.puresuzuki.com/anvil_axle.htm[/url])
That link or URL is outdated -- the new one:
http://www.calmini.com/detail.php?b=2&m=5&t=3&p=694&n (http://www.calmini.com/detail.php?b=2&m=5&t=3&p=694&n)
