ZUKIWORLD Discussion Forum => Build Diaries, How-To, DIY => Topic started by: tonyman246 on March 24, 2010, 03:00:08 PM
I didnt start this project with making a writeup in mind, but i thought i might share some of my experience with you. This way if you are contemplating taking the body off of the frame you know what your in for. I started disconnecting things from the rear then moved toward the front then to the motor.
<br>
1. Unbolt the gas filler neck.
<br>
2. Remove wires from fuel pump.
<br>
3. Disconnect emergency brake lines from inside cab.
<br>
4. Remove wire on rear differential. (not sure what its called) And remove axle vent tube.
<br>
5. Remove speed sensor from trans.
<br>
6. Disconnect steering shaft.
<br>
7. Remove shift boots.
<br>
8. Disconnect ignition coil from distributor.
<br>
9. Unplug O2 sensor.
<br>
10. Disconnect brake booster vacuum line.
<br>
11. Disconnect heater core hoses. (may need to drain radiator to keep from dumping a lot of fluid)
<br>
12. Disconnect MAP sensor vacuum hose
<br>
13. Remove brake line and clip from inside driver fender.
<br>
14. Remove ground wires from coil
<br>
15. Remove either computer OR unplug all wires from engine.
<br>
16. Disconnect throttle cable from motor.
<br>
17. Disconnect clutch cable.
<br>
18. Im sure there are steps i didnt encounter that you might. this was just how my 1991 2 door tracker 1.6L 8v came apart.
<br>
The reason i did this was so i can work on the frame and do all my armor and bumpers and rock sliders with the frame off. I will also try to re route all the wiring so it will be a little less likely to get wet. It took 4 hours with me working and my friend handing me tools. All and all, wasnt too bad of a job.
<br>
ALSO IM LOOKING FOR SOME IDEAS ON WHAT TO DO. AXLES, MOTORS, DRIVETRAIN, ANTHING. what would you do if it were broken down like this?
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Nice start, and thanks for the information. What are YOU trying to do/make? The world is yours.
I would
Put rock sliders on the body. http://www.zukiworld.com/forum/build-diaries-how-to-diy/tracker-2x4-rockers-frnt-bmper-4-dr-sprngs-lwered-frnt-diff-$30-steel-frnt-diff/ (http://www.zukiworld.com/forum/build-diaries-how-to-diy/tracker-2x4-rockers-frnt-bmper-4-dr-sprngs-lwered-frnt-diff-$30-steel-frnt-diff/)
Install a longer swing 4 link suspension in back.
Do a 2" frame chop and drop (if you are staying with IFS). Then I would take two inches out of the strut towers, and install GV springs in front.
And to spend the money you saved by doing this yourself, I would get a tc doubler (your choice).
Keep us posted with your progress.
