ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zuktinter on November 12, 2009, 06:43:20 PM
Title: samurai steering stabilizer recommendation
Post by: zuktinter on November 12, 2009, 06:43:20 PM
I have an 88 samurai with 2" body lift and 30" tires  in the last few weeks I am getting some wheel wobble and I am thinking it is the stock stabilizer,any    recommendation on what stabilizer I should go with? Thanks Mike
Title: Re: samurai steering stabilizer recommendation
Post by: CspgsZuk on November 12, 2009, 08:45:27 PM
I used an OME stabilizer for a few years until I went to power steering. I still have it. If you're interested PM me.
It is quite abit larger than stock and mounts like stock instead of a bracket on the pitman arm.
Post by: zuktinter on November 19, 2009, 07:38:36 AM
Does anyone know of one that its beefier than stock but bolts up as to the stock mounts?
Post by: Drone637 on November 19, 2009, 12:04:49 PM
The Stabalizer might help hide the wobble but you will just be hiding the rear problem.  I would look at your tie rod first, see if your joints are worn.  You might also want to have the balance on your tires checked.
Post by: zuktinter on November 20, 2009, 06:47:11 PM
the front end is tight the samurai only has 36K original miles on it,the over sized tires only have 1k on them but will definitely check the balancing on them.
Post by: zuktinter on November 21, 2009, 12:16:16 PM
Well I went and had my tires balances today and it turnes out my tires are out of round they are 15" 30  X 9.50 General grabber A/T tires with only about 1k miles on them  :-[
Post by: Drone637 on November 21, 2009, 12:31:49 PM
Can they true them up?
Post by: shakydoug on November 22, 2009, 10:17:45 AM
Check this out, found a"Gabriel Steering stabilzer Part # 14040" at Auto Zone. for 1987 Samurai.
