ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: ebewley on May 15, 2009, 09:13:31 AM
Title: FAQ - Frequently Asked Questions about Suzuki Samurai, Sidekick, Geo Tracker
Post by: ebewley on May 15, 2009, 09:13:31 AM
Frequently Asked Questions - Topic index.
Below is an index of frequently asked questions about Suzuki Samurai, Suzuki Sidekick, and Geo Trackers. Many similar problems and issues come up with vehicle ownership and with being new to owning a Suzuki. We have tried to capture as many of these question with answers as possible. This is an active list and we'd like your support to make it grow. Please feel free to post a thread suggestion if you have seen something here at ZUKIWORLD that you think would be of benefit to add to this list.
Thanks, ZUKIWORLD Staff.
What tires size can I run on my Sidekick?
- http://www.zukiworld.com/forum/index.php?topic=23.0 (http://www.zukiworld.com/forum/index.php?topic=23.0)
- http://www.zukiworld.com/forum/index.php?topic=324.0 (http://www.zukiworld.com/forum/index.php?topic=324.0)
What is my vehicle worth?
- Dude, really?
What are the tune up specifications for my Samurai?
- http://www.zukiworld.com/forum/index.php?topic=19860.0 (http://www.zukiworld.com/forum/index.php?topic=19860.0)
What year is my Samurai? 88 vs. 88.5
- http://www.zukiworld.com/forum/index.php?topic=25221.0 (http://www.zukiworld.com/forum/index.php?topic=25221.0)
What tire size can I run with a Calmini 3" suspension lift on my Sidekick?
- http://www.zukiworld.com/forum/index.php?topic=25192.0 (http://www.zukiworld.com/forum/index.php?topic=25192.0)
What are lockers and are they worth it?
- http://www.zukiworld.com/forum/index.php?topic=24758.0 (http://www.zukiworld.com/forum/index.php?topic=24758.0)
How do I build a budget minded 4 door Sidekick?
- http://www.zukiworld.com/month_050107/feature_budget-4doorbuild.htm (http://www.zukiworld.com/month_050107/feature_budget-4doorbuild.htm)
How do I install a 2" body lift on a Sidekick?
- http://www.zukiworld.com/month_120104/feature_sky_bodylift_install.htm (http://www.zukiworld.com/month_120104/feature_sky_bodylift_install.htm)
How do I remove the Shift on the Fly from my Vitara and XL7?
- http://www.zukiworld.com/month_030104/feature_tsb_shiftontheflyremoval.htm (http://www.zukiworld.com/month_030104/feature_tsb_shiftontheflyremoval.htm)
How do I lift my Sidekick with Grand Vitara coils?
- http://www.zukiworld.com/month_030104/feature_sidekickbudgetlift.htm (http://www.zukiworld.com/month_030104/feature_sidekickbudgetlift.htm)
How do I get 2wd low range in my Sidekick?
- http://www.zukiworld.com/month_120103/feature_rro2wdlowkit.htm (http://www.zukiworld.com/month_120103/feature_rro2wdlowkit.htm)
How can I stregthen my IFS front end?
- http://www.zukiworld.com/month_110103/feature_zigsbeef.htm (http://www.zukiworld.com/month_110103/feature_zigsbeef.htm)
- http://www.zukiworld.com/month_020103/feature_frontendupgradeswithhagen.htm (http://www.zukiworld.com/month_020103/feature_frontendupgradeswithhagen.htm)
How can I raise the gas tank on my Sidekick?
- http://www.zukiworld.com/month_080102/feature_hagen_gastanklift.htm (http://www.zukiworld.com/month_080102/feature_hagen_gastanklift.htm)
How can I get better driveline angles on my Sidekick?
http://www.zukiworld.com/month_100102/feature_hagans_rearrotate.htm (http://www.zukiworld.com/month_100102/feature_hagans_rearrotate.htm)
How do I gain more stability? Widening the IFS.
- http://www.zukiworld.com/month_120102/feature_hagan_frontendmod.htm (http://www.zukiworld.com/month_120102/feature_hagan_frontendmod.htm)
How do I build stronger CV shafts for my IFS?
- http://www.zukiworld.com/month_040103/feature_hagencvshaft.htm (http://www.zukiworld.com/month_040103/feature_hagencvshaft.htm)
How do I set up and tune side draft carburators?
- http://www.zukiworld.com/month_050102/feature_dcoesetup.htm (http://www.zukiworld.com/month_050102/feature_dcoesetup.htm)
Will Samurai wheels fit a Sidekick?
- http://www.zukiworld.com/forum/index.php?topic=25162.0 (http://www.zukiworld.com/forum/index.php?topic=25162.0)
What kind of equipment should I take with me on the trail?
- http://www.zukiworld.com/forum/index.php?topic=4715.0 (http://www.zukiworld.com/forum/index.php?topic=4715.0)
My Samurai transmission shifter wobbles. What is the problem? A.K.A. Sloppy Shifter fix
- http://www.zukiworld.com/forum/index.php?topic=25492.0 (http://www.zukiworld.com/forum/index.php?topic=25492.0)
What kind of oil do I use for my differentials and how do I fill the transmission?
- http://www.zukiworld.com/forum/technical-discussion-beginner-repair/changing-differential-fluid-how-what-type-of-fluid/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/changing-differential-fluid-how-what-type-of-fluid/)
My power steering has suddenly got very difficult to turn, what could that be?
- http://www.zukiworld.com/forum/technical-discussion-beginner-repair/94-trackkick-power-steering-is-hard-to-turn-now-input/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/94-trackkick-power-steering-is-hard-to-turn-now-input/)
What are the differences between the early 1.3 liter and the late 1.3 liter and are they interchangeable? 1.3a 1324cc vs. 1.3b 1298cc
- http://www.zukiworld.com/forum/technical-discussion-beginner-repair/g13a-and-g13b/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/g13a-and-g13b/)
How do I install a locker or mini spool?
- http://www.zukiworld.com/forum/build-diaries-how-to-diy/how-to-install-a-locker-or-mini-spool-step-by-step-with-pics/ (http://www.zukiworld.com/forum/build-diaries-how-to-diy/how-to-install-a-locker-or-mini-spool-step-by-step-with-pics/)
How do I turbo my Sidekick? Or, how do I turbo my Samurai?
- http://www.zukiworld.com/forum/build-diaries-how-to-diy/how-to-turbocharge-a-16v-trackick (http://www.zukiworld.com/forum/build-diaries-how-to-diy/how-to-turbocharge-a-16v-trackick)
What other vehicles have wheels that I can use on my Sidekick or Samurai?
- http://www.zukiworld.com/forum/technical-discussion-beginner-repair/92-sidekick-rims/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/92-sidekick-rims/)
How do I adjust the idle on my Samurai? Also, High idle adjustment.
- http://www.zukiworld.com/forum/technical-discussion-beginner-repair/87-sammie-high-idle-after-gets-up-to-temp/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/87-sammie-high-idle-after-gets-up-to-temp/)
More to come!
If anyone has time, I'd appreciate help with indexing...
