ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: AJMBLAZER on March 12, 2009, 06:01:25 PM
Title: '96 Tracker 2 door 4x4 - rear brake questions
Post by: AJMBLAZER on March 12, 2009, 06:01:25 PM
So I'm fairly sure my rear brakes are shot.  I knew they were thin but I drive all my vehicles like a stick so I tend not to use my brakes until I'm actually stopping.  They last me a long time, what can I say. :P
All of a sudden there's not much rear braking going on and my foot moves quite a bit more before I really feel the brakes grab.  Reminds me of when we regeared it and the rear brakes took a few days to finally seat in right.
At any rate, what size are the rear brakes?  Some sites just list by 2 door vs 4 door and others list sizes...which I'd bet means the 2 doors get the smaller brakes?  Anyone know the dimensions?
Thinking about getting a parts kit as well since the truck has about 180k on it.  Anything else I should pick up while I'm at it?
Title: Re: '96 Tracker 2 door 4x4 - rear brake questions
Post by: Rhinoman on March 13, 2009, 11:41:59 AM
2 doors have the smaller rear drums. I think mine were 297mm but mine were Lucas/Grling so yours may well be slightly different.
Post by: Uncivilized on March 14, 2009, 06:37:03 AM
All you really need are the shoes and spring kit. Unless your drums are bad, or you have a leaky wheel cylinder... but you won't know that till you get them off.
Post by: ack on March 14, 2009, 07:23:32 AM
Sounds like you have worn the shoes down until they actually are not close to the drums anymore.  This would explain how the pedal does not "feel" contact for a while as you push on it.
You might check your front pads while you are at it...  Also check the slide pins on the front calipers.  One o mine "fell out"  :o causing braking to be a bit spongy.  I reinstalled new ones with Locktite and things felt a lot better.
I "engine brake" a lot on the Hypnotoad too.  The only bad thing about that its that it confuses all the "Amateurs" driving behind me...
"How can a vehicle slow down without putting on the brakes??"
