ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: beercheck on October 11, 2008, 06:28:15 AM
Title: Blown headlight bulbs....BOTH!
Post by: beercheck on October 11, 2008, 06:28:15 AM
Last night I discovered both of my headlight bulbs' low beam filaments blew out.  Brights were fine.  All other bulbs are fine.  I don't know if it happened right then, or if it happened sometime throughout the day (with the daytime running lights).
Anybody got a theory for an electrical gremlin that could be responsible?  The bulbs were less than a year old, both replaced at the same time (so I had a still-good spare bulb in the glovebox, since only one bulb had actually gone bad before), and it's been dry here for days.
I've had both headlights burn out within a day or so of each other before, but never, ever, both at once.  It's freakin' me out.
Title: Re: Blown headlight bulbs....BOTH!
Post by: Armour on October 11, 2008, 06:56:44 AM
I have had it happen to me before! Unexplained and it was fine after. Prob a spike or something????
Post by: beercheck on October 11, 2008, 07:03:58 AM
I'm leaning toward that explanation, but I still can't wrap my head around two bulbs blowing instead of a fuse.
Come to think of it, is there even a headlight fuse?  Maybe the bulbs are their own fuses?
Post by: Uncivilized on October 11, 2008, 08:00:16 AM
I've had everything blown, both low beams, then while driving with the high beams on to get home, one blew.... then the other.
I replaced the bulbs and all was fine. One year later, I noticed something green on the passenger side inner fender well wire harness - it was fuzzy corrosion. Not sure if it was related, but I was having a horrible time with my headlights turning on by themselves whenever there was a hard rain. Haven't had a big rain yet to find out if it was the exact problem.
Post by: Merlin93 on October 11, 2008, 08:32:30 AM
This would be a good time to measure, even monitor, your battery charging voltage. A small, cheap Digital Volt Meter (DVM) will work.  Harbor Freight frequently has them on sale for $3.  The life of tungsten filaments is very sensitive to applied voltage. That means even a 10% increase in applied voltage results in only one-third of the design life (it's a 12th power relationship!). The charging voltage should be between 13.5 and 14.5. It's possible a bad sense wire or regulator is causing the alternator to run uncontrolled.
Of course, this may not be it, but it is a good place to start. Headlight bulbs have a well-defined wear-out mechanism and generally fail within a short time of each other. When the first one blows, the second is not far behind -- replace both, as you did.
Post by: beercheck on October 11, 2008, 08:46:53 AM
I've got one.  Is there a preferred circuit in the cabin where I should wire it?
Post by: bentparts on October 11, 2008, 06:05:30 PM
I think he means to check the running voltage, right at the battery first, while running, than at the lights themselves, while running.
Post by: beercheck on September 02, 2009, 03:21:02 PM
Ooookay.  An update...
I've found that high-performance bulbs burn out damned quickly on my truck ('02 XL7 for this conversation).  If I get 6-months, I'd be surprised.  I haven't had both go out at once again, but I continue to burn through 'em.  Normal halogen 9003s last pretty long.
I'm currently of the belief that it's been happening because of the automatic-on (light-sensor) feature.
If I turn the headlight switch 'ON', then turn on the brights, the low-beams turn off.  BUT, if the headlights (low-beams) are on due to the light sensor turning them on automatically, and I don't turn 'ON' the headlight switch manually, when I turn on the brights, the low-beams also remain on.
What I think is happening is that I'm cooking the hotter high-performance bulbs by running the brights with the lows remaining on.  I love the extra brightness, but damn, expensive bulbs get expensive!
Anybody else notice this?
Post by: Drone637 on September 02, 2009, 05:09:55 PM
I ran into the same issue with the bulb burning out.  Your probably correct in that the driving lights take a lot of the life out of your bulbs, there have been a few write-ups on how to disable the running lights.  I believe the relay is under the dash.
I just ordered a pair of bulbs from Summit Racing for 11 per bulb.  We'll see how they hold up.
Post by: fordem on September 03, 2009, 05:30:40 AM
Yes - the "high performance" bulbs do have a shorter life span, the higher perfomance is achieved by designing the lamp filament to run at a lower voltage so that it is overdriven at the nominal 12V.
Regarding that "auto light" feature - there may be something incorrectly wired somewhere, it is supposed to do it's on/off magic through the #1 headlight relay, which is the same relay that switches the lights on from the manual switch, so the low beams & high beams should operate exactly the same no matter how the lights are turned on.
Post by: beercheck on September 03, 2009, 06:46:56 AM
Hmmm.  I hadn't considered a miswiring possibility.  I'm 99+% sure I transferred all the wiring over faithfully as stock from the donor truck, but it also had an aftermarket remote starter (which rocks) installed.  I suppose that installation may have mildly boogered something up.  I can look into that.  Thanks for the suggestion.
Post by: essjay on September 03, 2009, 02:41:58 PM
this doesnt really fix your problem, but I recommend you buy "eurodezigns" headlights, I ran them in my focus since I bought it in 2002, one set, lasted 5 years, and they were VERY bright, I was/am pleased with them.
Best thing, if they do blow out, you put one bulb in a regular letter sized envelope and put duct tape around the sharp edges, put a money order for 6 bucks in it, a letter with your name on it, and they send you a new set.
You cant beat it, I would get some for my sammy, but theyre sealed beam.
