ZUKIWORLD Discussion Forum => Build Diaries, How-To, DIY => Topic started by: littlefoot on May 16, 2008, 08:12:54 AM
Shop Vac Snorkel
I know there are several threads on this already but I took a slightly different approach. Here’s a light-duty snorkel for a Sami you can put together for about $75 (if you buy everything new) a lot at less, if you have a donor shop vac lying around. I refer to it as “light duty� because it is NOT intended for deep-water crossing. Just a little added insurance if a mud hole or stream is deeper than it looks (or you happen to be the one that finds the big rut).
The hose, tubes & fittings are all 2.5� shop vac accessories. I chose this diameter because that’s the diameter of the inlet on the air cleaner (retain the rubber elbow & clamp). The OEM set-up actually chokes down the inside diameter to less than 1.5� in the pre-heat valve. This setup adds about 36� to the end of the stock intake tube length-wise but is probably no more restrictive because the ID is the same all the way down. It should actually breathe a little better. Personally, I think its much cleaner looking than PVC or ABS pipe & fittings. About half the people who have seen this since I installed it don’t recognize it as a modified vacuum hose!
The key components that make this project work are the 90° fittings and the aircraft cushion clamps. The 90’s are actually right-angle brush attachments. The brush & trim rings are easily removed (they pop right off the end) leaving you with the same tapered ends as the extension wands. I ordered the 2.5� clamps (MS211919-DG40) from an internet aircraft parts supplier. Again, it lends a clean purpose-built look you can’t get in the plumbing department. By-the-by, these “Mil Spec� clamps come in a full range of sizes and have just as many uses on a 4x4 as they do on an aircraft (brake lines, wire harnesses, on-board-air tubing, vacuum lines, fuel lines, etc). All the tube joints, except the top two (explanation below) are glued & clamped for security & water tightness.
This arrangement has a few advantages over the prefab set-ups. One of which is it can be configured in one of two ways; inlet facing forward (for “ram� air) OR; inlet facing backwards (for foul weather). It still allows for opening the hood and/or lowering the windshield. The intake “hood� must be removed (& later reinstalled) to open the hood all the way back or fold the windshield. Also, if the top of the snorkel gets snagged on something (or visa versa), it should pivot away and/or separate before it breaks. I’d rather stop to pick up & reinstall something that got knocked off than pick up pieces of something that broke. And, last but not least, if it does break, replacement parts are easily obtainable at any home improvement store.
The main disadvantage is the components themselves. You have to work with the vac tubing and connectors as they are. The pieces are tapered to fit together one inside the next. If you modify them, the taper at the new connecting points is incompatible and the resulting pieces are useless (I cut up one 20� extension trying different configurations – it didn’t work).
The photos should explain the rest. Feel free to throw out comments or questions. If I get enough requests I’ll take the time to do a more detailed “How To� article.
well if your ever in need of vacuming your sam all you would need is the vacume lol, pretty cool though arent you worried about branches breaking that backwards?
Home made eniginering at it's finest.If it works it works.Besides,when you tell people on the trail what it is made of I think you will get cool reactions.
Yup gots me a 63HP Shop-Vac! Beat that!!! ;D
It's "designed" to come apart before it breaks.
what did u use for the rubber on the hood and how is it working since u made it
Very Nice, clean work. The details make it.
