ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: kubik1981 on March 19, 2008, 10:10:11 AM
Title: 1990 8v tracker idle problem
Post by: kubik1981 on March 19, 2008, 10:10:11 AM
ok i finally got my tracker running good now the only problem is that when it warms up it idles at 1500 rpms.  Does anyone know how i can change this.
Title: Re: 1990 8v tracker idle problem
Post by: lostsamurai on March 19, 2008, 03:27:59 PM
set your timing at 10 degrees BTDC and work your way to 8 or 6 see where it idles right and has no hesitation, if that's not it make sure the throttle cable isn't  too tight it shouldn't have play but shouldn't be tight either, then you can try your tps it will change your idle significantly
Post by: Armour on March 19, 2008, 08:09:21 PM
Also check for vacumm leaks. A vacuum leak could cause this!
