ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: phloop on November 17, 2007, 03:10:46 PM
Who knows what the fuel tank capacity of a Sidekick is?
my 2 door tracker is like 9 or 10 gallons i think
10.6 gallons... US..
depends if it's a 2dr or 4dr ... and the year ...
90-98 2dr == 11.1
90-98 4dr == 14.5
X90's == 11.1
99-05 2dr == 14.8
99-05 4dr == 16.8
01-06 XL7 == 16.9
06+ GV == 17.4
I am looking at getting a mid 90's 4dr and was wanting to kinda figure out the mileage I may get with one.
depending one whether it is a manual or auto, how you dirve it, and the tire size, you will probably get between 20-26 mpg. My 1990 got about 25 with the stock tires, and 23 with the 225/75r15s.
This rig will be kept stock and used as a DD. If I want to wheel in a lifted rig I will just jump into the Sammy.
I have a 94 tracker with the 8 valve. It is stock except for the 1.5" lift, waiting on tires untiil I see if we get laid off in January. I got 27.43 miles to the gallon. I commute so I just did a K&N air filter, PowerMax 7mm ignition cables and new plugs and I am now 30.92 MPG. I feels a little better on the throttle as well. Especially on the top end and on hills.
Cuthulu, what did those plug wires run you? And are they any better than stock?
