ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: TrAkLsI on April 12, 2006, 11:43:12 PM
Title: jeep tj coil spacers
Post by: TrAkLsI on April 12, 2006, 11:43:12 PM
is it safe to run a jeep 3" spacer to the rear of a 95 2dr tracker thanks,
Title: Re: jeep tj coil spacers
Post by: the_maplebar on April 13, 2006, 07:07:29 AM
You know you will have to modify the jeep spacer right?  You have to bore out the center hole to fit.  As far as being safe; I think so, but you axle will bind on the pinion mount before you get much droop if you go that high.  So you will need to fab up a pinion mount spacer too.
