ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: feerocknok on March 05, 2006, 09:16:28 PM
Title: Lincoln Locker
Post by: feerocknok on March 05, 2006, 09:16:28 PM
Pros?  Cons?  Rear only?  Trail only?
Toy axles (on a Toyota truck!), running 31s now, hopefully 35s or 37s come summer.
What type of experience do you guys have with these?
Title: Re: Lincoln Locker
Post by: brlj on March 06, 2006, 02:10:47 PM
If your talking about welded spider gears, Id say dont do it....  If you want a totally locked rear go with the minispool.
If your street driven a Lockright or ARB.
Ive seen a bunch of welded spider gears and most of them, when I took them apart, were on the verge of breaking.
Post by: Chief on March 06, 2006, 04:48:28 PM
Have quite a few trail rides on mine, and done some street driving with it also. Very predictable, no lock/unlock BS. When I swap axles, the rear is getting it again!
Post by: 87kevurai on March 06, 2006, 08:21:26 PM
I welded mine and havent had any problems yet.  it is the same thing as a spool but about 50 cents compared to $130 for a spool because if an axel shaft breaks with a spool you are just as screwed as if a welded one breaks.
Post by: purpletracker on March 06, 2006, 08:32:27 PM
mine's weled also ..i DD mine ..chirp around corner ..i drive with crappy stock tires on as DD and put on my nicer tires for trail
Post by: feerocknok on March 06, 2006, 11:06:06 PM
This is trails/rocks only.
I've seen 2 guys on the intraweb run em front and rear with 38s, but it kinda worries me.
What's the difference with a minispool?  They seem cheap enough to think about.
Post by: Quaddawg on March 07, 2006, 02:09:52 PM
Yeah, welding will USUALLY hold... but since a mini is so cheap... I vote Mini-spool
That's what I run,  since you have to take the carrier apart to weld the spiders anyway, might as well drop in a mini-spool... I got mine from Randy's R&P  works great... and I don't have to worry about a welded spider coming loose and trashing my 3rd member or worse...
I am going to put it in my 5.62's and sell the 5.12's with the lockrite that the 5.62's came with...
Post by: feerocknok on March 11, 2006, 03:24:56 PM
I heard about something with magnetic something or others inside the diff housing.  I guess it was to catch any loose metal?  Would this make a lincoln more desirable?
My grandfather is Jewish, and has given me a fourth of his blood, so I'd like to be stubborn and cheap, but I don't want to be stupid.
Post by: Quaddawg on March 11, 2006, 11:47:54 PM
LOL... then weld the everloving bejesus out of it! Every gear, every hole, every cog... doesn't cost any more then just welding it up a bit.. and it ain't gonna break... LOL...
as long as everything spins true...
We are talking what, 80 horsepower here?  LOL....
If you have $110 or so.... buy a mini spool... if you have have $800 or so, buy an ARB... if you got a few good sticks and a welding hood... make it one piece...
One main reason I bought a mini-spool, was because you have to take the diff apart to get to the spiders anyway... it's not like a GM corporate, or a Dana, where you can pull the cover off the diff and spin and weld....  I have a buddy that can weld up spiders in less than 10 minutes... LOL....
I also just thought a mini-spool would be easiest, as the pinion depth and pinion bearing preload aren't effected by installing it, and all I had to do was reset the carrier bearing preload and backlash.. and that is pretty simple...
Post by: feerocknok on March 12, 2006, 12:19:23 AM
80???  This is a Toyota...  maybe 65.
Lol, I might look more into a minispool just cause of the workload.
Post by: brlj on March 12, 2006, 07:23:40 AM
Now this is one area where I think the welds failed.. They didnt take the carrier apart to weld the spiders. All the welding was done thru the holes to the side of the carrier = not much quality weld.
Post by: purevil71 on March 13, 2006, 03:45:44 AM
I had VERY good luck running a LL in my sami axles, and I'm running it in my Toy axles as well.
I'll be on 36" swampers as well, and I'm not too worried about it.  I'm running a welded front with P/S and possably hydro assist in the very near future.  BUT, if that dosen't work out, I'll probably go with a locker up front, but I'm keeping the welded rear.
My rig will be 90% trails, with the occasional drive through town just to see every one gasping and parents hiding there small childern out of fear of parts falling off and hitting them....lol
Post by: feerocknok on March 13, 2006, 10:33:14 PM
Your rig sounds awesome!
How's the front do?
What usually causes these to get their bad reputation
