Zukiworld Feature Article: Project ZR3
  • 62 Replies
  • 23480 Views
0 Members and 21 Guests are viewing this topic.
Re: Zukiworld Feature Article: Project ZR3
« Reply #30 on: November 09, 2010, 01:00:16 PM »
That is totally cool.  I've always liked the looks of the 2ng gens better than the 1st gens.  This last summer I could have bought an 03 Tracker with hard and soft tops and 100k miles for $5000.  Instead I bought an 05 Wrangler Unlimited for more than twice that.  Now I get to pay through the nose for gas.  I wish I had stayed with a Zuk!
You can always come back to the 'Dark Side'  >:D
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #31 on: November 09, 2010, 05:15:17 PM »
However, I have 31 spline ford spiders mixed with a suzuki lock rite locker in a tracker rear being used as a front diff in my buggy. After all that I would think the XL7 issue should be fairly simple. Just gotta figure out how much crap needs to be machined ;)
I don't remember reading about running Ford spiders in a Tracker rear.  Are you using spiders from a 8.8 or a 9"?
They are from a 9 inch. I never did write up anything on it. 37kicker and I were just diggin through a pile of parts one night and realized that a nine inch side gear had the same tooth count as a tracker. We were having a few beers at the time and our imaginations were working overtime. Next thing you know the grinder was in hand and the lathe was turning.  :)  We changed the pitch thickness and overall diameter of the face. Then turned the bearing size down and machined out the tracker carrier. There is a little more to it than that, but all in all it was just good times.
Offline keith
  • 1176
« Reply #32 on: November 09, 2010, 07:33:34 PM »
How necessary was the V6 swap?  What kind of gas mileage did it get on the trip?
« Reply #33 on: November 09, 2010, 07:54:30 PM »
I can tell you, without the turbo, my truck on 33s with 5.83s
is a slug on the road, to have this as a road going truck and
not a trailer queen, you will want more power just to keep
from getting run over by slow moving semi trucks  ;)
« Reply #34 on: November 10, 2010, 04:56:03 AM »
More Power! Always a good thing.
« Reply #35 on: November 10, 2010, 11:17:43 AM »
Great.  Now I'm going to be looking at what it would take to use cut down Ford 9" axles in the rear...
Offline meach4x4
  • 59
« Reply #36 on: November 10, 2010, 03:34:18 PM »
When you get to that point, why not just swap in a 9"?  With the shaved pumpkin you would get close to the same clearance and have a 9" ring gear.
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #37 on: November 10, 2010, 07:58:31 PM »
True, but keep in mind an XL7 rear is nearly a 9 inch ring gear. If you swap to a ford 9 you have to buy brakes, gears, pinion flange, and make lots of brackets for links, shocks, coils ect.
« Reply #38 on: November 11, 2010, 03:54:21 AM »
This is where if we were kids sitting around looking at your new toy,  I would be the one jumping up and down yelling , " now do mine, do mine!"  ;D
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #39 on: November 11, 2010, 05:54:34 AM »
I built this one with an automatic so I my kids would have an easier time driving it. Both of them have been driving it quite a bit. Eventually I will swap a 5 speed into it. I am not a fan of autos.
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #40 on: November 11, 2010, 06:06:17 AM »
I dont know how necessary the swap was but I just wanted to not have to have the gas pedal to the floor everywhere I went. My old orange rig was always to the floor. Oddly both rigs fair about the same mileage. 18 with my regular (hard) driving and 21 driving nice. That being said the V6 is alot faster. I think that It would do a lot better if it had a manual trans. Im not a fan of this auto.
« Reply #41 on: November 11, 2010, 08:13:43 AM »
I averaged 15 to 17 MPG with the turbo, on 33s with 5.83 diff gears
on my trip to Moab when I drove there in the Sidekick, and I have
the old 3 speed auto trans.
It's not the trans it's the driver with the MPGs  ;) that and redline all the time
Offline Frank84
  • 176
« Reply #42 on: November 11, 2010, 09:12:37 AM »
How do you like the new BFG mud terrains?  Mine is a daily driver and I'm just as concerned how they are on the road as off.  Noise is probably the biggest issue for me that kept me with all terrains last time I bought tires.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
  • 6557
  • 64
« Reply #43 on: November 11, 2010, 09:30:43 AM »
You know, I got some new KM2 last year and I am AMAZED at how quiet they are. Way better then the old BFG MT, similar but better than the BFG AT, and better than the old Goodyear MTR. ...and they work good offroad too! Tire tech has come a long way in the last few years and I think these tires benefit from new developments and technology.
YMMV
« Reply #44 on: November 11, 2010, 10:34:20 AM »
And it wouldn't be legal for the Zukiworld Challenge.  You have to keep a Suzuki rear housing.  :D
And we are a lot lighter.  Those 9" axles are heavy buggers...
