SO my 1996 tracker which I had bought just recently also throws a p0400 egr malfunction code just like everyone else who has the 96 or newer trackers. It also throws a p0171 system lean code. Now, the guy I bought it from obviously tried and tried and tried to get these codes to go away, with no success.. he replaced the oxygen sensors, not sure if he replaced the cat or not, but it looks fairly new, he claims he cleaned the egr and what not, and he also claims he replaced the ecu.
Well, I figured I'd check everything for vaccuum leaks, there are none, I took off the egr it was fairly clean but I went ahead and cleaned it a bit more, as well as the tube, and the port on the intake manifold that everyone gets clogged or is only the size of a pinhole. I also went ahead and cleaned the MAF sensor, reset the computer by disconnecting the battery, and the check engine light goes away, like it should, but after driving for a good 100 miles or so it always comes back on.
Now I think I have narrowed the problem down, the egr solenoid valve which has one line coming out one end, and two lines coming off the side on the opposite end and it it has a two wires going into it which are blue black and green red. I have checked the wires with my multimeter and get nothing. Heres my first question, since this is a solenoid its only gonna get electricity sent to it by the ecu when it feels it is the correct time to do so.. right? Or is it supposed to be constantly fed with 12 volts and then it drops when the ecu feels its the right time?
Next question, if something in the egr system isnt right can that be what is setting of the system lean code too? Or could it be the fuel regulator and how would I check that?
Lastly and the reason why I call this thread wiring from hell, is because this guy also f*cked with the wiring like you wouldn't believe, probably to see if there where any shorts anywhere causing these problems, since replacing the oxygen sensors didnt solve the problem like he thought it would. He obviously didn't do any research before attempting to tackle these codes.
So here are some pics of the wiring from hell.. the guy obviously unravled all the wiring harnesses, and he taped together some relay (red arrow in picture) and also wrapped tape all around some white plug (green arrow) that also has a few random wires taped into the mess that arent attached to anything! so what is this relay and what is this white plug that isn't attached to anything if anyone knows?
I will be adding more details and pics to this adventure tommorow when I have more time to look at it.. oh yeah, I almost forgot to mention, amidst these codes and terrible wiring, the car runs great, starts right up plenty of power no hesitation at all, but it gets around 17-18mpg and thats if I drive it nicely...
