My 92 tracker has a check engine light on (I reset the switch did not help) and it will idle and run but if you accelerate fast it wants to die I jumped the wires for the codes but I got nothing. When I turn the key to run there is a click from a relay and from one of two vacuum valves under the hood. I have a second truck and tried replacing all of these parts but did not work.
Any Ideas? Or does any one want a 92 side kick with hard top (removable) and Ac and a 93 tracker soft top (needs new front dif and exhaust work and driver side window). I would like $800 for both. They are near Albany Ny.
