Suspension question
  • 9 Replies
  • 1943 Views
Offline explosivo
  • 3157
Suspension question
« on: August 23, 2004, 05:52:39 PM »
If a fellow were to SAS a vehicle, say a Tracker, and fabricate a 4-link suspension for the front, would this fellow be better off leaving the back with all the Calmini 3" stuff, or should this fellow do a similar 4-link setup for the rear and ditch the third link?
omghi2.us[/url]
Offline suzi_n_sammy
  • 184
  • Rock the Sam
Re: Suspension question
« Reply #1 on: August 23, 2004, 05:58:00 PM »
I would think do a similar 4-link setup for the rear and ditch the third link.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #2 on: August 23, 2004, 06:59:54 PM »
My buddy from the flint area did a four link and his flex diminished. Why do you have some last minite plane's ;)
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #3 on: August 23, 2004, 07:11:39 PM »
I like the 3 link better, But not the current designs available.  Needs longer links and more travel.
« Reply #4 on: August 23, 2004, 07:55:24 PM »
If you place the pivot end of the links
the same distance as the driveshaft is
from the axle, and the same pivot point
of the driveshaft you don't have any
slip yoke problems, as they pivot the same.
One of my next projects one of these years
Offline 1bigtracker
  • 3409
« Reply #5 on: August 24, 2004, 08:09:40 AM »
i would try to copy cat the RRO coil set up for a sammy.  looks easy enough to build.
stu
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #6 on: August 24, 2004, 09:58:33 AM »
i modified mine like wild suggested and it works great. however i maade a braket to bolt to my third member and used a hime-jointto conect to the third member. i must confess i didn't think of this my self i got it off a friend. i also moved my axle back 6" and plan on another 6" after my sas. keep the springs because coilovers suck when they get full of mud.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline explosivo
  • 3157
« Reply #7 on: August 24, 2004, 02:45:42 PM »
So the goal is to make the links pivot at the same point as the driveshaft?
I wasn't planning on using coilovers, because on top of the mud problem (which is primarily what offroading consists of up here) they're really expensive compared to coil springs, correct?
omghi2.us[/url]
Offline explosivo
  • 3157
« Reply #8 on: August 24, 2004, 02:48:28 PM »
Nope, just gathering info for future projects :)
In fact, I'm actually thinking of parking the Tracker up north and getting something more reliable to drive for the next year or two.
omghi2.us[/url]
« Reply #9 on: August 24, 2004, 06:28:59 PM »
That would give you the best movement
without dropping the DS on the trail, and
will reduce the driveline angle to the minimum
