How do you modify the lower strut hole to fix camber issues on a lifted tracker?
The strut bolts to the knuckle with 2 bolts. The top bolt is the on you modify. Here's how I did mine for a 2.25" total front lift:
I removed the top bolt, then pushed the spindle in towards the strut until it stopped.
I used a die-grinder with a good cutting bit, and ovalized the hole till the bolt went back in and through the knuckle.
Done!
I have a thread here somewhere with a few pictures, I'll find it and update later.
