Roll cage for my 86
  • 1445 Views
Roll cage for my 86
« on: September 25, 2011, 11:31:41 PM »
i want to cage my sammi front and rear, is it worth buying the cage from petroworks and installing it myself? is it easy? or should i call in some favors and try to fab one myself?  any input is greatly appreciated!!
Re: Roll cage for my 86
« Reply #1 on: September 26, 2011, 09:30:17 AM »
If you have access to a welder I would recommend the cage from Davesport.  You can get a front weld on kit or a complete roll cage, which is what I run.
Offline kreator
  • 634
  • 15
« Reply #2 on: September 27, 2011, 12:51:56 PM »
Where are you located ?
« Reply #3 on: September 27, 2011, 05:15:19 PM »
I don't know what kind you have but if you have the full cage for the soft top you can still put up the top and take it down right?
« Reply #4 on: September 27, 2011, 09:00:07 PM »
Yes, it works fine with the stock soft top.  Here is a picture with the full cage added onto the existing roll bar:
And my full cage, without the back add-on but not using the stock roll bar, as the SJ-410 doesn't come with one:
