This is a must do item for me so I figured I'd start up a thread as I go.  I'm currently in the Information gathering / planning stage.
I am looking to flip the Sidekick steering to the top of the knuckle and make it a solid respectable streetable unit.  This will require the steering tie rods, joints, tapers, and angles to be correct (or as close as possiable). ÂÂ
TO begin I am researching the Tie Rod flip on Google.
THe results were much better then those on Pirate 4x4, But Pirate did have the entertaining Butt Picture thread.  Anyway,  Google shows the Tie rod Flip kit is available at: ÂÂ
http://www.ok4wd.com             ÂÂ
http://www.djmsuspension.com           ÂÂ
http://www.rockcrawler.com           ÂÂ
http://www.jamesduff.com           ÂÂ
http://www.downeastoffroad.com           ÂÂ
http://www.goferitoffroad.comMy thoughts are to research the different kits and applications (Jeep, Bronco / II, Chevy, Scout, ect) and find which one will most closly represent what we need by asking these questions.
 1. Are their any with the same Suzuki Sidekick taper?
ÂÂ
 2. How is the taper measured?  (Metric / SAE) & what values?
ÂÂ
 3. Are their any of these currently in use for IFS steering (Chevy, Bronco II)
 4. Can I adapt one of the current (Jeep, Chevy, Ford) flip kits and factory style tie rod to the stock Sidekick Center link and tie rod set up?
 5. Is a IFS tie rod designed to work at greater angles then a Solid axle one.
 6. Is their a Tie Rod Flip Kit in place for the Jeep Liberty
of other similar IFS vehicles?
 7. Can I mix Dana 30 and Chevy IFS parts, S-10 steering should be plenty compared to factory Kick.
  I have fabricated steering parts for my personal use on and off road for over 7 years.  Can I simply just build a Jeep tierod end that will bolt to the Suzuki Center link?  Can I modify Chevy / Jeep steering linkage to work as my Kick Centerlink and Tierods?
  It almost looks as though I can buy 4 of the press in & weld type inserts and install them in the Pitman Arm, Idler, and both Outer Knuckles.  Though I am still fascinated with the Ideia of a Chevy Moog idler arm (though the arm legnth may be to long / Idler and pitman should be equal legnth). ÂÂ
  Starting from scratch gives us the unique opertunity to use extra Beefy components, But at what point are you just adding weight and wear.  When fabricating steering overbuilding with in reason is the standard.  ÂÂ
Listed below is a Screen shot of Goforitoffroad.com's Set.  I could buy and ship all 4 tapered inserts for Less then $70.
This is not an answer that will be found over night.  Heck I'm going to be on a Weeks vacation in a few days, so litttle may become of this for a week or two.  But I would soon like to make 33" and up tires on an IFS kick a reality that I can achieve safely.
I will not install this:
On This:
![](http://photos.zuwharrie.com/users/whitfimb/Spyphoto.jpg)
