I looked at OTT, they only have kick to sami/yota adapters. With my 4.24:1 t-case and stock t-case. I would be able to run 35's.
Quote from: Hawkeye Huey on October 21, 2008, 04:51:09 PMI looked at OTT, they only have kick to sami/yota adapters. With my 4.24:1 t-case and stock t-case. I would be able to run 35's.The Kicker 3 allows you to put a Sammy T-Case behind your box, it has a high range drop of 20% built in. Then you can drop the lower gear kits in as required as each Sammy T-Case Gear set has a lower high range then stock.
Dual case would add alot of gearing options, Is there a tracker/tracker t-case adapter?
Quote from: Hawkeye Huey on October 21, 2008, 12:22:44 PMDual case would add alot of gearing options, Is there a tracker/tracker t-case adapter?I have read a lot of threads, and have NOT found a tracker/tracker dual case. I would be very interested if someone has made one. I also have a spare tracker tcase, and would love to have/create a dual case setup.
I emailed aftermarket4x4 asking for some information. I'll pass on what I find out.
