+1 for the 1995 model. Even some 1994's. Especially if you are looking at 4 doors.
1994 and 1995 were still simple (ODB1) and were 16 valve.
No airbags. Airbags started in 1996. (Depends on personal preference here. I hate the idea of airbags while wheeling.)
Plus, my front passengers love my rollercoaster bar. (See Bob's pic above of 1995 dash)
I feel that ODB1 is simpler technology, and easier to diagnose. It just takes one little wire to make a jumper between two connectors on one plug under the hood to diagnose what a check engine light means. Plus, you also have the check engine override switch behind the dash to turn it off when it comes on at mileage intervals.
Personally, I wouldn't recommend a Sport, even though they look cool and have the 1.8 valve. I've heard too many mixed reviews on the engine for it. Some people have had good luck, though.
EDIT: Forgot to mention 1994-1995 trim levels. In the Suzuki line up (not geo) They have the JS, the JX, and the JLX. The JS is a two wheel drive model. The JX is your basic 4wd model. The JLX is 4 wheel drive, but has electronic door locks, power windows, and somewhat nicer interior (like a deluxe model).
EDIT Part Deux: Things to look for at mom/pop lots:
Take a phillips screwdriver with you and pull off a rear tail light. Check for rust.
Lay underneath and check for leaks, rust, etc. Check the bottom of the frame rails and the exhaust for scratches and dents (to see how it was treated/offroaded, etc).
Open the hood and check out the valve cover gasket area. Also, the distributor area, looking for oil leaks, as these are the most common places.
Check the oil, see if it's milky. Check the radiator fluid, see if it's clean.
Start it up, listen to it run. A little sewing machine action is fine, loud noises might be something worth checking out.
Cruise it around, feel up the transmission. Spin hard circles in forward and reverse in a parking lot to feel and listen for CV joint issues.
Put it in 4WD and lock in the hubs if they are manual and drive in a circle in both directions, checking to make sure it goes into 4wd and everything meshes right. If they are auto hubs, listen to the front hubs to see if they make any noise while in 4wd.
Hope this helps!
