Volksuki Bugurai project
  • 21 Replies
  • 5320 Views
Offline airdreams1
  • 90
« on: April 03, 2012, 08:11:39 AM »
Figured this needs a better title.....
A bit about me first & what I have in mind.
Ive been a bug nut since the 90's....   Ive owned 8 or 9 VW's in that time... 1 Manx,  2 bajas & the rest strreet.    2000+ VW toys or so in my colection.(last count was about 7 years ago)
   Ive always loved that  a highly moded VW motor can eat almost anything out there! (ferrari's mustang's, corvet's, etc.)  & even a mildly moded Baja can go almost anywhere a a jeep, toyota, sammy, broncos, blazers,  etc can go.      & yes Ive been there my self & proved it to many unbelievers.
Yah, Im a huge VW VW nut...  But am getting tired of having to rebuild the motor all the time. (I use my baja like a truck! Yes even I tow with it)
Here are a couple pics of the baja Ive been rolling. & as you can see I dont like the "norm." Nor do i fit in well with the local VW club.... they all either hate what I have done to my bug, think its wired, etc... I dont care what people think, I just do what I want & what I like.  It was bought as a wrecked rolling carcus...  As for the custom/fab work, Ive done it all my self & constantly am making changes....
if you want to see more pics you can check it out |removethispart||removethispart||removethispart|@ http://www.shoptalkforums.com/viewtopic.php?f=28&t=124932&hilit=66+baja
So, in looking at the samurai, it looklooked like it would fit the VW baja body prety easly. wheel track width is the same as my baja.   Frame & drive line (wireing,brale lines, etc) would need to be stretched about 15 inches   & it would look cool having a Baja sitting up on a 4X4. Not something you see every day. Or ever as far a s I can tell.  + I love working on projects.
This is the Samurai I bought.  It is all stock except a webber carb.
After getting it home it appears the motor is junk. It seems to have a blown head gasket acording to my mechanic friend (water in the oil & oil in the radiator) + burns lots of oil so it wouldnt pass emitions here in ADA County. :rolleyes:  It also has a remote silinoid on the fire wall for some reason. & after being ran it wont start again for about an hr or so,  till it cools down.
Ultimatly I want a 1.6 for it & auto trans, but was hopeing to get by with this motor for a while. Guess its going to be a longer wate to get it going :lame:  Guess I way over payed for a vehicle again."shaking:
Anyway, I want a 1.6 & auto trans....  I also plan to run 31 10.5 tires.
Any help with what all I need or best/ cheepest ways to go about the motor, wireing, & trans swap  would be greatly appriciated.      OH  & I need this thing to be reliabal & pass emitions. It will be a DD/recreational off roader & need to tow a light trailer as well.
& I bought a set of new rear OME springs & will be getting some for the front.
« Last Edit: May 20, 2012, 04:44:30 PM by airdreams1 »
87 Samurai  soft top
Offline mrfuelish
  • 2862
Re: New to Zuki's
« Reply #1 on: April 03, 2012, 08:55:33 AM »
There is a golf cart sitting on a samurai frame in Emmett that looks cool not too far from you, my brother lives near you and I would pass by it going to his ranch.
Offline Jonny Rash
  • 1094
  • 21
Re: New to Zuki's
« Reply #2 on: April 03, 2012, 09:10:24 AM »
Nothing wrong with VWs.  I own two in addtion to all of my Suzuki stuff.  One is a 1956 Beetle that I brought back from Germany and the second is a 1981 Rabbit Conv my dad bought new.
As far as the lowest cost conversion-find a Sidekick/Tracker at a pull it yard and take everything off it or buy a rolled/wrecked one.
Re: New to Zuki's
« Reply #3 on: April 04, 2012, 01:33:32 PM »
as clean as the sam's body looks you should be able to get a pretty penny for it! mine was half wrotted away when i got it, and everytime i found a "new" tub it was just as bad. so endless hours of sheet metal work later, its back to normal....ish. i like your idea though! should be a fun build. 8)
Offline airdreams1
  • 90
Re: New to Zuki's
« Reply #4 on: April 04, 2012, 10:13:54 PM »
dam thing left me stranded the other day.  >:(
the starter was basicly toast. (& no it wasnt just the simple clicky fix)  I had to remove it, tare it down  & clean out all the grease,oil & dirt.  then needed to recut the com & clean the brushes.     Now it seems to start fine.
Going to try to get a "94" 16V  1.6 tomarrow.   But need to know what all I need to get from the doner rig...
here is what all I think I need:
~Motor, alternator, wire harnice & brain box......
Do I need the exhaust, starter  what else????????????
87 Samurai  soft top
Offline Jonny Rash
  • 1094
  • 21
Re: New to Zuki's
« Reply #5 on: April 05, 2012, 06:47:45 AM »
If the starter goes out, you can always push start it.  8)   Done that a time or too when a battery went dead or the starter went out.
Offline Boxcar
  • 936
Re: New to Zuki's
« Reply #6 on: April 05, 2012, 07:27:57 AM »
Did a VW convertable to Scout 800 swap 30 years ago. Yes it's been done allot.  The 800 is a closer fit.
 My daughter runs a 69 dub. Thought about doing the Vamy thing myself. I like the looks of the Zuke , so I shelved the idea.
You have a lot of work ahead of you. As I remember (it's been 30 years) you will have to loose about half the pan (tranny hump)
 build a fire wall (we used a steel wheelbarrow) and run the radiator out back.
The automatic will need to come from a tracker or kick so your gonna need another downer. Run the entire drive system from the Trackick. IE: engine, trans, and T case. As well as all the computers from the Kick.
Good luck....Boxcar...
God Bless
Offline Jonny Rash
  • 1094
  • 21
Re: New to Zuki's
« Reply #7 on: April 05, 2012, 08:06:24 AM »
Yes, I've seen several Suzuki Beetles on the web.  Here's one of the better ones.
http://www.hybridaction.com/bugzuki/index.htm
Offline airdreams1
  • 90
Re: New to Zuki's
« Reply #8 on: April 05, 2012, 08:47:37 AM »
cool litle rig....  But still not a baja. ;D
87 Samurai  soft top
Offline Jonny Rash
  • 1094
  • 21
Re: New to Zuki's
« Reply #9 on: April 05, 2012, 09:22:24 AM »
Just remove the fenders.  ;)
Offline kreator
  • 634
  • 15
Re: New to Zuki's
« Reply #10 on: April 05, 2012, 12:51:04 PM »
I'll get some pics of one in my shop and post them  8)
Offline airdreams1
  • 90
Re: New to Zuki's
« Reply #11 on: April 11, 2012, 12:42:14 PM »
picked up a 1.6 16 valve motor, starter, powersteering pump, alternator, air box, dizzy, computer & most of the parts needed for the swap.  still need to go back & get the harnice, power steering box.  find an exaust (they wouldnt sell me any of the exhaust!) & none of the local yards will sell the cat.  (they clame it may have a hole & would need to be preasure tested.  ::)) I think thats a load of B.S. they just want to scrap them for the $)
Jut need to sell off some more of my crap so I can buy more parts for this thing.
87 Samurai  soft top
Offline airdreams1
  • 90
Re: (name change.) Volksuki project
« Reply #12 on: April 13, 2012, 09:17:37 PM »
got my wire harnice today  and the starter + alternator I forfot |removethispart|@ the counter.  ::) also realized I didnt get the tube that connects the airbox to the intake, so I got that.     but the speedo was sold >:(,  so Im on the hunt for one.
87 Samurai  soft top
Offline airdreams1
  • 90
« Reply #13 on: May 01, 2012, 11:34:00 PM »
Got the title in my name.  Friday the inspector comes out to document the build & take pics of both rigs....  So hopefully Ill be getting to start workig on it soon. ;D
87 Samurai  soft top
« Reply #14 on: May 02, 2012, 10:07:09 AM »
Congrats!  Soon, no more garage space!  :)
