The "needle" - I am guessing - would be the needle valve on the injector. The Suzuki dealer said he tried cleaning it, but it didn't seem to help, hence the possible need to replace it. The check engine warning light comes on and off, and the dealer does not seem to be able to determine the problem - it has been in and out of the shop 3-4 times. We have replaced the fuel filter; the EGR valve; the coolant temperature sensor; spark plugs; and have also tried using fuel injector cleaners in the gas tank. Nothing has helped... it runs good otherwise, but the idle is annoying and also makes it difficult for low range 4X4 crawling...
As suggested, it might be the Idle Speed Control solenoid valve. Sorry I don't have any pictures.
Can anyone suggest where I can purchase a really good shop manual? I have the Haynes Automotive Repair Manual, but find that the instructions are not specific enough...
