Hello all,
In early December we had a real cold spell (almost thought I was in MN) and on the low of lows (-10 or so) the thermostat locked closed. I figured out htat the heater wasn't working and made the guess about 15 miles later. Anyhow, after replacing the thremostat, it started to run very poorly after it reached something in the range of warm. What it does is start to miss badly, especially below 3000 rpm. It will idle down for a few seconds, then die if I don't keep the rpm up (after ti gets warm).
I replaced the temperture sensor for the computer, as well as the MAF unit (found one off of an X90 reasonably priced). I have an OBD2 code reader and had nothing to read for the first week or two except 'engine missing' -- duh! The other day it had 4 failure codes, including the temp sensor, barometric pressure, MAF, and something else (don't have the list handy). I pulled the plugs: All are very clean-- no brown or black
![Shocked :o](https://www.zukiworld.com/forum/Smileys/aaron/shocked.gif)
(just a couple of months old; strikes me as too clean).
I am tempted to at least get a large resistor to match the temp sensor and ground it (got to look up the circuit to make sure it goes to ground, etc). At least it should run okay.
What I really want to do is fix it. Vehicle has 148000 on the clock and is a 5 speed. Any ideas?
