rear passenger window issue on '92 sidekick 4 door
  • 1027 Views
Offline RJkick
  • 632
« on: January 08, 2008, 11:35:26 AM »
Well, the window went down and up really slow yesterday and then stopped doing either.  I removed the door panel and some of the rain proofing plastic to see what happened.  The cable had 2 loops sticking out of the regulator, took an hour but I managed to pull those out.
It looks like the cable may have busted since the end of it is now stuck in the top plastic wheel where I assume it used to go around, pulley I suppose.  Does the end mount to something on the window or can I JB weld it to where it broke off or is it the best option to just purchse another regulator\cable assembly?
I looked at a haynes manual but can't tell where the cable mounts to
Any inexpensive replacement suggestions or schematics of where the cables mount?
Offline chet
  • 556
  • Zuki time!
Re: rear passenger window issue on '92 sidekick 4 door
« Reply #1 on: January 08, 2008, 07:55:07 PM »
I had the exact same problem with the exact same door! the cable is supposed to make a loop. search on ebay for a co that sells PW motors they didn't have the door listed but by going to their site I found it. cheap like $50 only prob was they would send to Canada to I got a set of manual back doors off a friend and put those on.
Offline RJkick
  • 632
« Reply #2 on: January 20, 2008, 05:59:09 PM »
Turns out the cable is kinked on the spool
Does anyone know if you can get another or just buy another motor\cable
If so does anyone know a good place to get one?
kingzoo
« Reply #3 on: January 21, 2008, 01:32:54 PM »
   I checked around myself for parts for my 91 Sidekick,but it was easier and allmost as cheap to replace the entire regulator.Like he said,check EBAY that is wher I got mine for $56 shipped.
Offline RJkick
  • 632
« Reply #4 on: January 22, 2008, 01:11:49 PM »
Excellent
I'll check ebay
www.aftermarket4x4.com has some as well and I'm waiting on the price
I have it so it is stuck rolled up so it is all good
