Trying to get more front end travel....
  • 17 Replies
  • 5883 Views
Offline RJkick
  • 634
Re: Trying to get more front end travel....
« Reply #15 on: May 04, 2009, 01:24:50 PM »
Exactly!, if you ever want to buy parts just send one of us Oregon guys the money and we can get them for ya. Should be cheaper that way right?
Better than 4wheel parts truckfest?  I hear they give ya about 20% to 25% off the retail
I was looking into rockmolesters OME springs, struts, daystar spacer, mx6 rear shock (actually a 97+ front shock) write up
http://www.pirate4x4.com/forum/showthread.php?t=444978
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: May 04, 2009, 05:33:21 PM »
I think Mike Hagen tried this a few years back, the struts were too soft for the front of the Track/Kick. It would be worth sending him a PM and asking him about this.
You are correct. I did this 5 years ago. The struts are softer which was ok but they failed at a suprising rate. They cant handle 2 hours of my off road driving. I cut them apart to see why and the internal tubes are too thin. They were streched and crushed. I gave it several tries. I think I went through close to a half a dozen struts before I gave up on them. I sure didnt save any money as I ended up buying OMEs anyway. :-\
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #17 on: May 04, 2009, 07:04:48 PM »
Thanks for the heads up Mike. Guess I will just save up for some OME's.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
