I run 1" wheel spacers on my Tracker. I used to run the 2", it worked well but I kept rubbing against the back side of my fender wells when trying to turn sharply. So I wouldn't go more then 1".
As for the offset wheels vs spacers, they put the same load on the hubs. A good set of true spacers should be just as stable as an off-set wheel.
