Well I guess it could get extensive, you need
the center for the shifter to come thru, the
pedal and any brackets that hold it, the cable
of coarse the trans and all the various things
that are attached to it, the speedo will read
different as the man Trans is designed to go
with 5.12 R and P gears, the speedo gear is
in the T-case so get the one from the donor
vehicle
I think that's about it, cost
Depends on the
wrecking yard, I'd guess about $300-400 for
all the stuff.
