tracker rear end
  • 22 Replies
  • 3433 Views
0 Members and 14 Guests are viewing this topic.
Offline tracker8v4x4
  • 128
    • cardomain
tracker rear end
« on: March 11, 2008, 05:56:16 PM »
does anyone know what size bolts are for the rear end mine all broke and now i need to tap them so i need to know all the tread sizes and has anyone swapped a rear end how hard is it thanks matt
  • 128
    • cardomain
Re: tracker rear end
« Reply #1 on: March 11, 2008, 06:26:21 PM »
this might be a stupid question and i dont kno how it would work but do they sell a diff fluid that locks both wheels on a slick suface better than normal i thought i heard somthing about this
Offline Element
  • 1902
  • LillyKicker
« Reply #2 on: March 11, 2008, 08:14:26 PM »
Hey 8v, what exactly broke, what bolts are you referring to?
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
Offline ROSS
  • 1412
« Reply #3 on: March 11, 2008, 08:19:02 PM »
no such fluid
  • 128
    • cardomain
« Reply #4 on: March 11, 2008, 08:21:18 PM »
the top 4 bolts do u know the size of them? thanks
« Last Edit: March 11, 2008, 09:03:15 PM by tracker8v4x4 »
Offline ROSS
  • 1412
« Reply #5 on: March 11, 2008, 08:23:02 PM »
give everyone a day or so you'll get the answer
be patient grasshopper
  • 128
    • cardomain
« Reply #6 on: March 11, 2008, 08:56:06 PM »
sry if i was sounding impatiant i was answering the guy aboves question i should have quoted it
« Last Edit: March 11, 2008, 09:01:09 PM by tracker8v4x4 »
Offline mic
« Reply #7 on: March 12, 2008, 07:33:11 AM »
Which four bolts? The ones holding the V-bar to the diff? I also have some snake oil to lock your wheels better jk :)
91 Tracker Calmini 3+3 31x10.5 swamper ssr
88 samuri 3" body 2"susp. 31x12.5 boggers sold
03 super duty daily work truck $$$$gas
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: March 12, 2008, 10:14:54 AM »
The "special Oil" you are refering to is for certian kind lockers/limited slip diff that have clutch plates to make them work.
If you use the wrong oil you can destroy the material on the plates so that the locker wont work.
96 Tracker
32 MTR's Warn 8000i
  • 128
    • cardomain
« Reply #9 on: March 12, 2008, 02:01:36 PM »
yea those 4
« Reply #10 on: March 12, 2008, 08:59:03 PM »
And actually what that does is it makes the oil "slicker" so the clutch plates don't "chatter".
  • 128
    • cardomain
« Reply #11 on: March 12, 2008, 09:53:00 PM »
i think i confused viscosis sp? locker witch uses a chamber of special fluid and works as a lsd
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
« Reply #12 on: March 14, 2008, 01:49:10 PM »
They make a special fluid for Limited slip diffs the increase the friction of the clutches, but it is only for LSD's or a posi. It wont do anything for an open differential.
Offline Armour
  • 360
« Reply #13 on: March 14, 2008, 05:13:05 PM »
If I remember correctly those bolts are like M10x1.25 or M10x1.00.
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
« Reply #14 on: March 14, 2008, 05:13:31 PM »
I think you are referring to the "limited slip additive" that I was referencing earlier......it is not to increase friction in the clutch plates (I thought the same thing for awhile), it is to make it so they don't chatter.
