Hey 8v, what exactly broke, what bolts are you referring to?
give everyone a day or so you'll get the answerbe patient grasshopper
Which four bolts? The ones holding the V-bar to the diff?
The "special Oil" you are refering to is for certian kind lockers/limited slip diff that have clutch plates to make them work.If you use the wrong oil you can destroy the material on the plates so that the locker wont work.
They make a special fluid for Limited slip diffs the increase the friction of the clutches, but it is only for LSD's or a posi. It wont do anything for an open differential.
