Tracker rear axle shaft removal
  • 6864 Views
Offline explosivo
  • 3157
« on: June 11, 2006, 09:13:02 AM »
How in the heck do the rear axle shafts come out of the housing in a Trackick rear axle? I removed the four nuts that hold the drum on, took the drum off, and then removed the four nuts that hold the axle retainer deal around, but unlike my D44s, the axle shaft only comes out a couple inches and then completely stops. Any help is appreciated.
omghi2.us[/url]
Re: Tracker rear axle shaft removal
« Reply #1 on: June 11, 2006, 09:28:24 AM »
Slide Hammer, the bearing comes off with the axle shaft
and can be a %#$|removethispart|@&  to get off. I built a slide hammer
out of an old twisted axle, put bolts thru the end and a
section of heavy square tubing, was 2 pieces of angle iron
for the hammer, works like a charm
Offline explosivo
  • 3157
« Reply #2 on: June 11, 2006, 10:34:42 AM »
Hrm, making a slide hammer... I'm gonna go try it out and I'll be back with some pics :D
omghi2.us[/url]
Offline mrfuelish
  • 2862
« Reply #3 on: June 11, 2006, 09:04:12 PM »
You can also use a high lift jack or a piece of chain and something heavy hooked to it.
Offline explosivo
  • 3157
« Reply #4 on: June 11, 2006, 09:17:55 PM »
Got the shafts out tonight with the slidehammer I made.
Slide hammer:
Friend using slide hammer to remove the driver's side shaft:
Thanks for the tip, Wild ;)
omghi2.us[/url]
Offline Speedracer7c
  • 2210
« Reply #5 on: June 12, 2006, 03:57:30 PM »
When i couldnt get mine out, I bolted the brake drum back on put the tire on and smashed it with a sledge. Came right out.  ;)
Offline pcguy
  • 343
  • 1996 Tracker 4x4
« Reply #6 on: June 12, 2006, 04:23:37 PM »
you could always have some work done at just brakes, they will leave some nuts/bolts out and the axle will come out on you going around  a random corner somewhere........ ::)
