Myth or truth...replacing tranny fluid is bad for tranny?
  • 16 Replies
  • 3417 Views
Offline idaholwb
  • 772
Re: Myth or truth...replacing tranny fluid is bad for tranny?
« Reply #15 on: September 17, 2008, 12:10:56 PM »
I don't know much about trackers but with GM in the picture I believe it will need a specific type of ATF GM style you know dexcool coolant crap the red antifreeze
Dexcool didn't even come into the picture with most of the GM line-up till the mid 90's. The Tracker doesn't use anything special as far as transmission fluid is concerned. Just basic Dexron-Mercon. And is your statement to try to compare the Dexcool with what special fluid the transmission might take or thinking one is the other?
97 Sport
265/70-16s
2" lift
2.0 swap
Offline tracker8v4x4
  • 128
    • cardomain
« Reply #16 on: September 17, 2008, 05:11:22 PM »
i have heard the same thing as well but most people say if it hasent been done on a regualar basis then use a additive such as lucas when changing it
