Tracker Distributor
  • 17 Replies
  • 2864 Views
wildphil69
Tracker Distributor
« on: January 13, 2008, 02:55:45 PM »
I have a sammy with a 95 tracker 16v and i need a distributor for it that willl hook directly to the msd with no igniter...was there ever a points or magnetic pickup dist for this? or does someone make one?
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Tracker Distributor
« Reply #1 on: January 13, 2008, 03:48:07 PM »
89 and 90 Sidekick 1.6's came with traditional ignitions.
Student of Now Master of Then
« Reply #2 on: January 14, 2008, 05:14:21 AM »
95 Tracker 16V should have a Hall Effect sensor or VR sensor inside the distributor. 8V Track/Kick has Hall Effect sensor, Sammy has VR sensor, you just need to remove the igniter. Does the MSD have advance built in because the 16V dizzy rotates in the opposite direction - that reduces your options.
wildphil69
« Reply #3 on: January 14, 2008, 11:11:27 AM »
It has a hall efect type...The msd guy said it needs an igniter but you need the ecm to make the igniter work right?
« Reply #4 on: January 14, 2008, 02:39:21 PM »
Can't you use the stock Suzuki igniter? What signal do you get out of the MSD? I know that my late 2000 model 8V has a 5V signal from the ECM. The Sammy one needs 12v.
wildphil69
« Reply #5 on: January 14, 2008, 07:11:45 PM »
msd needs 12v....i dont have an ecm because im running propane...or it needs a magnetic pickup signal
« Reply #6 on: January 15, 2008, 04:53:39 AM »
Let me rephrase the question. Do you need an igniter to run the MSD or does it have its own built in.
wildphil69
« Reply #7 on: January 15, 2008, 12:54:50 PM »
In the first post i said it the dis. i have needs an igniter...
« Reply #8 on: January 15, 2008, 01:45:41 PM »
Ok but AFAIK the MSD doesn't, which model is it? Is your igniter internal to the dizzy (there are at least 4 different dizzys)? is the coil built in too? If you can take a pic of the dizzy with the cap off that would help.
wildphil69
« Reply #9 on: January 15, 2008, 07:25:48 PM »
No coil...it is the 95 1.6 16v the rotor just has 4 tabs sticking down to pass through the pickup
« Reply #10 on: January 16, 2008, 11:58:49 AM »
Like this one?
Are you trying to run this with the stock EFI? Also you didn't say which MSD system.
« Last Edit: January 16, 2008, 12:00:48 PM by Rhinoman »
wildphil69
« Reply #11 on: January 16, 2008, 03:15:57 PM »
Yes that one...6AL...Propane
« Reply #12 on: January 17, 2008, 12:41:32 PM »
You need to follow the wiring instructions 'General Import Wiring', MSD call the igniter the amplifier. If you wire to the Hall Effect Sensor then you won't get any advance.
http://www.msdignition.com/pdf/6%20series/6series.pdf
I have one of those dizzys that I was going to use on a project. Can you tell me what the wire colors are?
Cheers
James
wildphil69
« Reply #13 on: January 17, 2008, 07:29:45 PM »
What kind of igniter do i need for that?
« Reply #14 on: January 18, 2008, 04:54:19 AM »
Use the stock Suzuki igniter
