tire lean
  • 16 Replies
  • 4570 Views
Offline trackenator
  • 38
  • I love YaBB 1G - SP1!
tire lean
« on: April 30, 2005, 03:29:55 PM »
hey gruop. my 92 tracker has a 3in body lift and 2in tj coil spring spacers. i run 31 x 10.5 x 15 in tires. at home in the driveway the front tires at the top lean in. but i drive to work and park and they lean out.everything is tight and i have no movement in the front. any ideas?
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: tire lean
« Reply #1 on: April 30, 2005, 03:46:34 PM »
Are you backing into one of these parking spots?
Ford trucks have IFS and the front will kinda squat when you back them up.
Check your alignment. You should have it realigned when lifting it. Keep an eye on your treadwear.
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: tire lean
« Reply #2 on: April 30, 2005, 07:34:45 PM »
Fords lean in when backed up just in case you were wondering if it leans in or out.
I almost paid alot of money to find out what was wrong when a buddy of mine goes they do that it's normal.
Mean Green Wheeling Machine
Offline chrisvitarasport94
  • 228
Re: tire lean
« Reply #3 on: April 30, 2005, 09:19:31 PM »
like on my  '94, the coil spacer lift has altered your geometry. it should have caused the tops to lean out.
easy fix $25 - adjustable camber bolts - speciality products ez cam (part# 81500 I think)
simple fit, and get an alignment - like new again!!!!!!
'94 3dr s/top Sport, roof bars, roof lights, Calmini bumper, SuperwinchEP9, CB & handheld, GPS, 2" body lift, skid plates, 2.5" susp lift, & hi-lift. Safari Snorkel. R Lockright
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: tire lean
« Reply #4 on: May 01, 2005, 04:14:23 AM »
exactly the correct answer the camber needs to be corrected. take it to a tire shop and they will tell u the same thing but they will tell u that u have no adjustment for camber on ur vehicle. that is why u must buy the camber bolts. however the camber bolts will not correct the problem intirely becuse they do not alow enough abjustment. u can either be happy with the correction they allow or grind the top hole in ur strut oval to be able to adjust. camber is how much the tire leans in and out. if ur friend has a newer ifs truck and it is lifted and it leans that is because the suspension lift was a cheep lift and it is not houlding the tire strainght or he may need to replace his bearings and ball joints. if it is twin Ibeam or ttb it is also out of alaignment and needs to be adjusted. yes the older fords do have some camber in and out as the suspension cycles but not just by backing up. win flexing on something, but defanetly noticable and full drop. the newer ford have a 2 a-arm setup which is suposed to hold the tire level throught the full range of motion. A TRACKER HAS A SINGLE A-ARM AND IT CAUSE IT TO MOVE TROUGH THE CAMBER ARCH AS IT MOVES UP AND DOWN. the trick is to get the camber set as level as possible for normal driving or ur tires will wear irregularly.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline wolf66
  • 193
Re: tire lean
« Reply #5 on: May 01, 2005, 05:04:42 AM »
How much coil lift can you use before you run out of camber adjustment on a Track/Kick (or X  ;))
I have the RRO 1-1/8" coil spacers now and she still is alignable, but i want to put in Sky Manfact. 1.5" coil spacers....think that will still be alignable?
And if not is there a web address for:
speciality products?
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
  • 228
Re: tire lean
« Reply #6 on: May 01, 2005, 05:55:35 AM »
with my +1.5" spring and +1" rro spacers, I could get proper adjustment using the standard recommended cam bolt, whcih I installed and set to maximum adjustment.
I seem to remember that they offer a bigger adjustment bolt, but that shouldn't be necessary,
after all, you love your CV's don't you, and 2.5" extra is enough for them !
I see it's the 81250 that you need ;
http://www.specprod.com/PROD_DIR/C_PROD_passcar_SEARCH_DYN.cfm?cmd=Cam&cmd2=81250&cmd3=58%2C%2061
« Last Edit: May 01, 2005, 05:58:20 AM by chrisvitarasport94 »
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
Re: tire lean
« Reply #7 on: May 01, 2005, 09:09:31 AM »
the tyres on my lwb vit still lean out at the top.
even after fitting camber bolts.
mind you it does have 4" of suspension lift.
but i have found that when its loaded up the tyres settle to the right camber.
Offline tracker8wr
  • 568
    • my home page
Re: tire lean
« Reply #8 on: May 01, 2005, 10:04:56 AM »
1 3/4 is the most. the other cambolts have very small shafts and could break off if u tighten them down to much. however that is my opinion and i have been wrong before.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: tire lean
« Reply #9 on: May 01, 2005, 03:17:48 PM »
I think this is a problem with your alignment. If your toe in or toe out is off it will cause the camber to change which is more easily seen but the naked eye.Camber can change when you move in reverse or forward if it is way out. If you wheel it much the Idler will bend quite easily. The smallest Idler bend will cause a lot of toe change. Sky MFG make a bombproof Idler for just under $100.  Cheaper than getting it alligned all the time or even worse burning an expensive set of tires off.
Mike
  • 228
Re: tire lean
« Reply #10 on: May 01, 2005, 07:57:45 PM »
yup, toe could cause this, but check camber first, and I guess toe is more expensive to correct
Offline zukin
  • 54
Re: tire lean
« Reply #11 on: May 02, 2005, 02:29:50 AM »
who sells the speciality products ez cam ?
do they have a web page?
Offline Agent Orange
  • 711
    • Trying to learn
Re: tire lean
« Reply #12 on: May 02, 2005, 03:44:58 PM »
this is what your looking for zukin
i bought mine from lordco, they had them in stock for $40 set.
Offline barcus
  • 97
  • fun
Re: tire lean
« Reply #13 on: May 02, 2005, 03:50:11 PM »
you may need this. by a japanese aftermarket manufacturer APIO. camber adjustment kit for escudo.
Re: tire lean
« Reply #14 on: May 02, 2005, 04:07:04 PM »
Those are well needed over here.
But only found in Japan?
That sucks. (for us in the U.S.)
