Well I wanted 4" lift, one to clear the 3" long
body studs that stick out of the bottom, that
and I had 2 body studs that had pulled out,
so I thought I might be doing something else
to get it all back together. I got a section of
Marine Exhaust hose, for the gas tank filler,
and a short piece of tubing to extend the
steering shaft, brake lines were a little easier,
the Drivers side fitting in the body can be bent
90* down to ease tension, and disconected from
the strut makes it fit fine.
Pass side I don't remember being any problem,
and the rear E-Brake needs to be slacked up a bit
from the wire guides, just bend them up and it
all works without pulling them too hard.
All in all an easy mod with a big reward in tire
clearance, sitting on 33s my rocker sills are 24"
from the ground so I guess that helps a little too.
